Outlook page not functioning properly
Posted: Sun Dec 10, 2017 9:42 pm
by Ron
I am having a problem getting my "Outlook" page to display information.
Perhaps I am missing something, a plugin? That provides the needed information. The only thing I can find different, (but it may have been that way before) is there are 2 commas where it is displaying the data source. It also doesn't show the data sources on the first page like the demo here does. The weather icons show NA.
The first page also shows extra space at the bottom.
This is a fresh install that I have been working on. I shut down my initial one, and moved to my other domain. The original place already had too much on it and it was just too much on that domain.
My meteotemplate is http://www.ronscountry.com/weather/temp ... esktop.php
Anone have an idea what I've done, or didn't do?
Thanks,
Ron
Re: Outlook page not functioning properly
Posted: Mon Dec 11, 2017 10:57 am
This means the conditions from DarkSky were not loaded, you are missing data and sources used by DarkSky. Try waiting a few hours before the cache expires. If this does not help and it worked on your previous installation there is likely a communication issue between your server and DarkSky
Posted: Mon Dec 11, 2017 2:10 pm
by Ron
Thanks, I'll give it time and check things on my end more.
SOLVED: I rechecked all settings after waiting a few hours. I double checked each one as if I were reinstalling. I found part of the DarkSky.net API had been left off. I replaced it with the full API code and it works perfectly.
Thanks, Ron
