Snow Data support for API
Posted: Mon Dec 11, 2017 1:05 pm
by MonyMony
For some weather data software, like WeatherCat, you can add in daily snow totals. Then the software allows this snow data to be pulled via a variable for use in what ever manner might be wanted. I will put my wish out there to include this in the API so that the snow data can be automatically populated in Meteotemplate and I can avoid the double data entry in my weather software and Meteotemplate.
Oh, and snow totals on the stickers too.
Re: Snow Data support for API
Posted: Mon Dec 11, 2017 9:20 pm
check if meteotemplateLive.txt has data for SN and SD
Posted: Mon Dec 11, 2017 11:20 pm
by MonyMony
Jachym wrote: ↑Mon Dec 11, 2017 9:20 pm
Currently my version does not:
{"U":1513034276,"B":262,"W":1.600000000000000088817841970012523233890533447265625,"G":3.20000000000000017763568394002504646778106689453125,"H":81,"T":0.5,"HIN":37,"TIN":21.39999999999999857891452847979962825775146484375,"RR":0,"R":0,"P":1015.740000000000009094947017729282379150390625,"LW4":0,"SW":"WeatherCatV2.44B2","UTime":1513034276,"BTime":1513034276,"WTime":1513034276,"GTime":1513034276,"HTime":1513034276,"TTime":1513034276,"HINTime":1513034276,"TINTime":1513034276,"RRTime":1513034276,"RTime":1513034276,"PTime":1513034276,"LW4Time":1513034276,"SWTime":1513034276,"D":-2.399999999999999911182158029987476766109466552734375,"DTime":1513034276,"A":-2.100000000000000088817841970012523233890533447265625,"ATime":1513034276}
Posted: Tue Dec 12, 2017 1:22 am
Right, ok, in that case however Im afraid it wont be possible
Posted: Tue Dec 12, 2017 1:01 pm
by MonyMony
I'm I correct that this is a limitation from WeatherCat and how it interacts with the API?
Posted: Tue Dec 12, 2017 11:46 pm
Yes, the API already has support for this... theoretically. It is not used by any block or plugin because AFAIK no software actually uses it
Posted: Sat Dec 16, 2017 9:21 am
by weather display
weather display software does allow daily input of snow data
so that could be add to MT via the api ?
Posted: Sat Dec 16, 2017 10:12 am
This is a bit more complicated because it would have to be overwritten each time until midnight to get the value for the whole day. This would require changes in the api.php.
What exactly does WD report for SN and SD? Current values? Yesterday´s values?
Posted: Sat Dec 16, 2017 5:35 pm
by weather display
WD has ability for a user to input current and daily/month/season
yesterday snow is also available
WD can also read live a lazer snow level sensor
Posted: Sat Dec 16, 2017 6:05 pm
Yes, so what exactly is sent as SN and SD via the API? Daily as in "today"? "Yesterday" ?
