WeeWX API vs Apache log
Posted: Sun Dec 24, 2017 7:32 pm
by RadekD
I'm sorry, I do not speak English, but Jáchym will understand.
Mám malý problém: od doby, kdy jsem propojil Meteotemplate s WeeWX pomocí API, začal mi neúměrně narůstat access.log od Apache. V intervalu od několika sekund po cca 1 minutu se objeví přibližně následující záznamy
:roll: Nobody responds, so I'll try to translate into English:
I have a little problem: since I connected Meteotemplate with WeeWX using the API, Apache's access.log began to grow disproportionately. Within a few seconds after about 1 minute, approximately the following records appear
::1 - - [23/Dec/2017:06:26:08 +0100] "GET /template/api.php?TBAT=1&B=68&G=9.72&RR=0.000&H=79.0&SW=weewx-3.8.0&P=1029.396&TIN=19.10&R=0.000&U=1514006768&T=2.50&W=5.04&P$
::1 - - [23/Dec/2017:06:26:10 +0100] "GET /template/api.php?TBAT=1&B=343&G=18.36&RR=0.000&H=79.0&SW=weewx-3.8.0&P=1029.292&TIN=19.10&R=0.000&U=1514006700.0&T=2.50&W=7.$
::1 - - [23/Dec/2017:06:26:11 +0100] "GET /template/api.php?TBAT=1&B=68&G=9.72&RR=0.000&H=79.0&SW=weewx-3.8.0&P=1029.396&TIN=19.10&R=0.000&U=1514006771&T=2.50&W=5.04&P$
::1 - - [23/Dec/2017:06:27:18 +0100] "GET /template/api.php?TBAT=1&B=135&G=8.64&RR=0.000&H=79.0&SW=weewx-3.8.0&P=1029.396&TIN=19.20&R=0.000&U=1514006835&T=2.50&W=3.60&$
::1 - - [23/Dec/2017:06:28:33 +0100] "GET /template/api.php?TBAT=1&B=315&G=8.64&RR=0.000&H=79.0&SW=weewx-3.8.0&P=1029.500&TIN=19.20&R=0.000&U=1514006904&T=2.50&W=3.60&$
::1 - - [23/Dec/2017:06:29:34 +0100] "GET /template/api.php?TBAT=1&B=0&G=12.24&RR=0.000&H=79.0&SW=weewx-3.8.0&P=1029.500&TIN=19.20&R=0.000&U=1514006974&T=2.50&W=6.12&P$
Dá se tomu nějak zabránit? Jde o to, že log zbytečně narůstá a stává se hodně nepřehledným.
Díky Radek
Is it possible to prevent it? The point is that the log grows unnecessarily and becomes very confusing.
Thanks to Radek
