Problem with [Weather / Outlook] Tab
Posted: Sun Jan 14, 2018 10:10 pm
by Dehatter
The METAR information shown on this page is not the correct data for the METAR closest to me.
Under sources the METAR is blank, and I cannot find where to correct this.
Please see picture.
Thank you!
Re: Problem with [Weather / Outlook] Tab
Posted: Sun Jan 14, 2018 11:12 pm
by John B
G'day, Tom,
Have you set up in your main set up page the details for your local METAR?
Posted: Sun Jan 14, 2018 11:15 pm
by Dehatter
Yes
Posted: Sun Jan 14, 2018 11:18 pm
by Dehatter
It is the same on your page too. The data in current does not match your METAR info either.
Posted: Mon Jan 15, 2018 5:04 am
That data is from WU using their airport stations.... so same problem as with the other blocks/plugins.... WU
Posted: Mon Jan 15, 2018 8:07 am
by Dehatter
Thank you for the explanation.
Any chance it could be gotten from the METAR information either in the block or the main setup page?
Just wondering.
Posted: Mon Jan 15, 2018 1:15 pm
The metar reports are inconsistent and also often unavailable. I know this because when I was creating some of the METAR blocks and plugins it was a nightmare. And most importantly, there is no history data, the official metar sources only give current conditions, the plugin shows history as well. The historical data is provided as GBs large files which can no way be processed by a script.
Posted: Mon Jan 15, 2018 3:44 pm
by Reinhard
My workaround for this one is to quote out the "airport"-line in the source code.
Posted: Mon Jan 15, 2018 4:24 pm
Thats what I will probably do unless WU fixes it soon
