Server migrated to new SS gauges no longer work
- BobW55
- Station model: Davis Pro2
- Software: Cumulus
My hosting site just switched servers on me an now my SS gauges no longer work.
When I use the test function from the template Admin page everything has a green check box.
I know I am missing something stupid.
Davis Vantage Pro2 wired
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
- Daali
- Station model: Ecowitt GW1002
- Software: Meteobridge, FOSHKplugin
Re: Server migrated to new SS gauges no longer work
is /template/homepage/blocks/ssGauges/ssGaugesBlock.php actually there? I see the Config.txt and index.php is, but get 404 trying to call it alone.
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
I see your site is 'offline' since 2021-09-18 07.55
Is cumulus updating correctly the new server?
- Daali
I can't find anything wrong really. I think it fails at the mysql portion of the php, which could be because the mysql data is too old or an issue with the migration.
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
- BobW55
- Software: Cumulus
Yes cumulus is updating.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
You should have a cron job calling update/update.php, is it still active ( maybe it was deactivated during the server migration )?
The cache/apiLog.txt timestamp is 2021-09-18 08:00:42 ( your local time ) this means that api.php has not been called ( by update/update.php ) since then.
- BobW55
- Software: Cumulus
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
Try calling 'manually' http://www.melvinweather.com/template/u ... ?password=*****
to see if it returns any error
- BobW55
- Software: Cumulus
Ran with SUCCESS
Do Have my page showing online now but still no update to SS Gauges.
Have sent email to my web host.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
- BobW55
- Software: Cumulus
Rewrote the cron job, now its working....
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
The cache/apiCache.txt ( which logs the values to be written in the database, it is cleared every 5 minutes ) shows the last 3
calls to api.php where on ( your local time ) :
"2021-09-21 23:46:03",
"2021-09-21 23:47:53",
- BobW55
- Software: Cumulus
Waiting on my hosting site.
Cron job is correct, and will execute with success if manually run.
Something on my hosting site is not allowing for that. I have placed a service ticket with them.
Funny Meteotemplate has been running for years without issue. When you run into one, you forget what you did to set it up in the first place.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
- BobW55
- Software: Cumulus
SOLVED:
Not sure what the issue was, something my hosting site did, but up and running now.
They had me write the cron job differently, but that still did not correct it.
ended up with the original cron job.
Go figure.
Go figure.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
Yes, that the kind of things that make me nervous
leonrossouw
I have several meteotemplate web sites one of which I have just migrated to a new host.
Everything works apart from the ssGauges ...they do not load at all.
I have gone through all the posts on this forum and to me there is no obvious answer.
I have reinstalled bith the ssGauges block and steelseries plugin.
Any suggestions ?
Leon Rossouw
Any suggestions ?
Leon Rossouw
I had a problem with the steelSeries plugin, resolved with this mod.
(Please provide a link to your site )
leonrossouw
Hi and thank you,
I have installed the mod steelseries plug-in...no luck yet.
See my link to web site :
http://cannonrocksweather.com/template/indexDesktop.php
Leon.
Leon.
