blocks and plugins
al60
Station model: Vantage Pro 2
blocks and plugins
Post by al60 » Mon Sep 25, 2017 6:17 am
Hello everyone,
The update to version 16 is perfect, all the tests are green.
On the other hand, in the installation of blocks and plugins I do not have the button "install new blocks"
during the update I have re-registered in the panel general configuration
Thank you for your help
(google translat :D )
Re: blocks and plugins
Post by Johnny » Mon Sep 25, 2017 8:13 am
Hi Alain, just a thought after doing the update, did you go to your control panel and under the 'Administration' section go to 'Main Setup' scroll right to the bottom and click 'Save'
al60
Post by al60 » Mon Sep 25, 2017 9:11 am
I clicked on "save" in the "Main setup" but it did not correct the problem. :cry:
thank you for your help
Thomas
Post by Thomas » Mon Sep 25, 2017 8:56 pm
Hi
We have same host (OVH) and all update functions do not work (and never worked)
The script can not retrieve versions of blocks / plugins ...
OVH blacklisted connections to meteotemplate ?
Meteotemplate have blacklisted OVH?
Station Météo Alès: www.meteoales.fr
Post by Jachym » Mon Sep 25, 2017 9:39 pm
Could be both to be quite honest, Im using external webhosting too, I have no control or overview of their firewall rules.
Are you using https?
Thomas
Post by Thomas » Fri Sep 29, 2017 8:58 pm
my webhosting tells me to add a user agent to use file_get_contents fonction.
Jeffm5690
Post by Jeffm5690 » Fri Sep 29, 2017 9:12 pm
Hey there Thomas.
What does that mean?
Sorry I’m not a php expert...
