updated windRose block
Added a couple of options to show wind speed information in different colors.
Speed scale and colors defined in options.
- windRose_1.2g.zip
- (4.68 KiB) Downloaded 1443 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Re: updated windRose block
perfect thank you
- meteolopik
- Station model: Davis Pro 2 Plus
- tobydude
- Station model: Netatmo
- Software: Weatherdiaplay
Great with colors.
Is it possible to add colors for highest "gust"?
https://fjærvollan.no/template/indexDesktop.php
What do you mean by saying "add colors for highest gust" and how would you like to represent it?
If I understand correctly you would like to superimpose, to the actual windrose, a line representing the 'maxgust' ?
( for example a radar graph superimposed to our windrose )
example radar graph windrose + "radar gust" ( you can clearly understand my "artistic" capability )
Not very easy to read/understand
- tobydude
"you would like to superimpose, to the actual windrose, a line representing the 'maxgust'",
yes, I guess that is what I ment.
I finally got the wind gauge on top of my roof, (today) and deleted det database for wind and direction.
Just to start from scratch.
Julius
- Software: meteobridge
How do you syntax these colors in the settings? I see no example config anywhere...
Mine looks really weird/empty now, using the latest windRose block:
ver 1.5
- added option to show max wind gust line
- windRose_1.5.zip
- (5.08 KiB) Downloaded 1063 times
Sorry, didn't reply to this post ( had a 'quite hard time' at work last april/may so missed a 'few post' )
- this is my setting:
Julius
The mouse-over for the wind gusts shows values that did not occur.. Some calculation is not working as it should.
Currently for example it shows for the 1h interval that there was an 80km/h gust, while we're only at 50km/h peak gusts according to stationData and the source weatherstation max value collected.
ver 1.7 ( 2024-01-10 )
- corrected gust speed ( was multiplied by 2 )
- windRose_1.7.zip
- (5.09 KiB) Downloaded 1105 times
hi something funny happened with the windrose....it's not a rose anymore.....
@Davidefa: any ideas?
- tobydude
Mine too.
But only in Opera browser.
