updated warningsEUregions
Weerstationwoerden
Re: updated warningsEUregions
Post by Weerstationwoerden » Sat Jan 06, 2024 2:12 pm
hi to you all
I have this block also on my site but its not update anymore
I see into the cache folder the file params.txt and warningsEURegions.txt
this files are up to date but if i look the txt I see the params.txt is not up to date
and the warningsEURegions.txt is ok
I see the info from the params.txt is on my site and not the info from the warningsEURegions.txt
is there a way for fix this ??
thanks
Gert
Post by davidefa » Sat Jan 06, 2024 3:09 pm
It seems working now. Not sure this is the case, but when you update the configuration of a block, remember to delete the cache ( if present ), or new content ( with new configuration ) will not be reloaded until the cache is expired ( generally after 1h ). This gives the impression that new settings are not correct.
Post by alexvanuxem » Sun Jan 07, 2024 6:11 pm
this one is working fine.
detail: is it possible to make the rss feeds also available in the 'warningsEU' block?
Thank you David for all your work!!!!
Grtz
Alex
Weerstationwoerden
Post by Weerstationwoerden » Sat Jan 13, 2024 2:20 pm
I have see the block works OK now
only the optic full screen is not works but that is no problem for my
T-man
Post by T-man » Thu May 16, 2024 7:45 pm
Hi
Downloaded the latest issue. I'm able to get warnings for other countries with map but Finland seems non functional. (tested also with mapall.php) Warnings for Finland come through but map is not visible.
-Timo
HILARIO
Software: WLIP
Post by HILARIO » Sun Nov 24, 2024 2:22 pm
Hello everyone,
I've noticed for a few days that the map in my "warningsEUregions" block has had some changes.
Now when alerts appear on the map, instead of appearing with the usual colors (yellow, orange, red) they are only seen in black.
Does anyone know if there has been any change?
Could it be that there is a change in the file: cache/params.txt?
I think this file is responsible for the alerts appearing on the map.
Can anyone check this error or incident?
lemimi
Post by lemimi » Sun Nov 24, 2024 10:42 pm
Good evening,
I just checked, this also happens to me:
https://www.lemimi.fr/template/indexFul ... sEUregions
Alvaro Poggiani
Software: Meteobridge Pro2
Post by Alvaro Poggiani » Tue Nov 26, 2024 8:05 am
Succede estattamente la stessa cosa anche a me, in Italia.
Cordiali saluti
alvaroi
https://www.meteovarazze.it
Screenshot 2024-11-26 085801.png (55.48 KiB) Viewed 61724 times
Post by davidefa » Wed Dec 04, 2024 6:32 pm
Updated the block as the rss feed changed a little bit.
ver 2.4 2024-12-05
- fix rss feed change
- fix finland regions definition
- fix 'sea boundaries'
http://realrunning.netsons.org/template ... ns_2.4.zip
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Wed Dec 04, 2024 8:25 pm
Thanks again, Davide, for the successful installation. Your help was invaluable! 😊
HILARIO
Software: WLIP
Post by HILARIO » Thu Dec 05, 2024 1:46 pm
Thank you very much Davide!!
The block returns to normal operations
lemimi
Post by lemimi » Thu Dec 05, 2024 3:28 pm
Same for me. Many thanks to you... Michel
Alvaro Poggiani
Post by Alvaro Poggiani » Fri Dec 06, 2024 2:23 pm
Grazie Davide, anch'io confermo che dopo il tuo intervento è tornato tutto a funzionare.
Alvaro
www.meteovarazze.it
Decon
Post by Decon » Sat Dec 07, 2024 9:39 am
Thank you for your work!
Alvaro Poggiani
Post by Alvaro Poggiani » Sun Dec 08, 2024 6:24 am
Non per essere pignoli, ma sembra che il blocco "Warnings EUregions" abbia voglia di scherzare,
(almeno con me)
Screenshot 2024-12-08 071335.png (87.69 KiB) Viewed 60931 times
Comunque va bene anche così
Ciao a tutti
Alvaro
www:meteovarazze.it
Post by davidefa » Sun Dec 08, 2024 11:21 am
Verify you have the last version installed.
I see your warningsEUregionsConfig.txt start with the following line ( which should belong to ver 2.2 )
{"version":2.2,"name":"EU Warnings - regional","namespace":"warningsEUregions","variables":[
Also after updating the software remember to clear the block cache.
Note
For example script warningsEUregions.php should be dated 4 Dec 2024
Alvaro Poggiani
Post by Alvaro Poggiani » Sun Dec 08, 2024 3:13 pm
Grazie Davide,
sono le persone come te che aiutano e insegnano alle capre come me.
Ho provveduto subito a porre rimedio al "disservizio" e ho atteso a risponderti che i risultati fossero almeno un po' consolidati.
Inspiegabile comunque quello che mi hai fatto notare, io lo colloco tra i "misteri gaudiosi" che la mia ignoranza, purtroppo, non mi consente di spiegare.
Venerdì u.s. ho installato la tua nuova versione (la 2.4) e nel ringraziarti per il tuo lavoro ti ho comunicato che tutto era tornato a funzionare (vedi mio post)
Ieri, l'Italia, è tornata ,,,"tutta nera" ma ti assicuro che io non avevo re-installato la versione vecchia 2.2.
Dopo la tua preziosa annotazione di oggi hon ricominciato dall'inizio:
fatta pulizia dell'installazione precedente, reinstallata la versione nuova di EUregions (2.4), ripulita la cache e le impostazioni di navigazione cancellando quelle precedenti come suggerito da Chrome e, come puoi vedere dallo screen, tutto è come dev'essere.
Probabilmente c'è stato qualche step che mi è sfuggito di mano inavvertitamente
(credo in matematica i misteri non esistano, nemmeno quelli gaudiosi)
e, come dicevo all'inizio, è grazie alle persone capaci e disponibili come te se anche chi non sa riesce ad imparare qualcosa.
Alvaro
www.meteovarazze.it
Screenshot 2024-12-08 154348.png (86.36 KiB) Viewed 60882 times
Post by davidefa » Thu Dec 26, 2024 9:38 pm
This block version is only for Norway, Sweden and Slovenia (which use 'polygons' in the meteoalarm.org warnings definition ).
All other countries should not use this version ( but this may change )!
ver 2.5 2024-12-26
- changed feed from rss to json
- use leaflet to show polygons on map
- added tooltip with warning description
- approximate coordinates:
Norway 64.91, 16.91, zoom 4.4
Sweden 64.08, 16.44, zoom 4.5
Slovenia 46.16, 14.92, zoom 7.8
http://realrunning.netsons.org/template ... lygons.zip
Meteo Heijningen
Station model: Ecowitt Wittboy GM2001
Post by Meteo Heijningen » Fri Dec 27, 2024 3:03 pm
I would like to advise the Dutch users to add a small change to the warningsEUregionsBlock.php as in version 2.4 for the Netherlands I found out, at least in my case, you will get no warnings.
In line 49 you need to change the "NL" to "nl" so lower case, (, 'nl'=>'netherlands',) then it works and you will get warnings.
Eddy
Post by davidefa » Thu Jan 02, 2025 5:28 pm
Meteo Heijningen wrote: Fri Dec 27, 2024 3:03 pm I would like to advise the Dutch users to add a small change to the warningsEUregionsBlock.php as in version 2.4 for the Netherlands I found out, at least in my case, you will get no warnings.
Eddy
Thanks, I updated the code.
tobydude
Software: Weatherdiaplay
Post by tobydude » Mon Jan 06, 2025 1:24 pm
davidefa wrote: Thu Dec 26, 2024 9:38 pm Re: updated warningsEUregionsQuote Jolumarali
by Jolumarali » Thu Aug 19, 2021 5:25 pm
davidefa wrote: Thu Dec 26, 2024 9:38 pm This block version is only for Norway, Sweden and Slovenia (which use 'polygons' in the meteoalarm.org warnings definition ).
ver 2.5 2024-12-26
This is greate!
Was not aware that there was a new version out as I´m not very good in opening christmas presents.
Thanks.
AnGeLiuS
Software: Ecowitt
Post by AnGeLiuS » Fri Mar 27, 2026 12:46 pm
Le bloc ne semble plus fonctionner.
Dans le fichier warningsEURegions.txt, j'ai :
<?xml version="1.0" encoding="UTF-8"?>
<rss version="2.0" xmlns:atom="http://www.w3.org/2005/Atom">
  <channel>
    <title>MeteoAlarm France</title>
    <link>https://meteoalarm.org?region=FR</link>
    <description>This RSS feed has been deprecated. Please use the Atom feed instead: https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-france</description>
    <language>en</language>
    <lastBuildDate>Fri, 27 Mar 2026 12:32:34 GMT</lastBuildDate>
    <pubDate>Fri, 27 Mar 2026 12:32:34 GMT</pubDate>
    <atom:link href="https://feeds.meteoalarm.org/feeds/meteoalarm-legacy-atom-france" rel="alternate" type="application/atom+xml"/>
  </channel>
</rss>
Merci d'avance pour ceux qui pourrait aider :)
Jolumarali
Software: WlIP
Post by Jolumarali » Sat Mar 28, 2026 9:34 am
bonjour
Legacy RSS Feeds Have Been Sunset on 2026.01.14.
As announced earlier, the legacy RSS feeds (meteoalarm-legacy-rss-*) have been deprecated and are no longer updated. Please migrate to the Atom feed format, which provides the same data and is actively maintained.
Les flux RSS hérités ont été supprimés le 14.01.2026.
Comme annoncé précédemment, les flux RSS hérités (meteoalarm-legacy-rss-*) ont été obsolètes et ne sont plus mis à jour. Veuillez migrer vers le format de flux Atom, qui fournit les mêmes données et est activement maintenu.
Davide au secours :D
