Another change at Netatmo
El_Viejo
Post by El_Viejo » Fri Mar 01, 2024 5:45 pm
Netatmo has just announced a new way to access station data. This change will start on May 24.
I am not able to understand if the change will affect the excellent work that "davidefa" did to change the plugin.
Can anyone find out?
Thank you very much.
El_Viejo
Re: Another change at Netatmo
Post by El_Viejo » Tue Jun 04, 2024 7:50 am
My fears have been confirmed. Since yesterday, the Netatmo plugin made by “davidefa” has stopped working.
The error message is: “Access token expired”.
Davide's selfless and efficient work was wasted by Netatmo's requirements.
We, the users of these stations, need Davide's active participation in the forum again.
El_Viejo
Post by El_Viejo » Mon Jun 10, 2024 6:20 pm
I have sent to ChatGPT the official Netatmo document about the current procedure for accessing their servers and, in addition, the “getNetatmoNet.php” file from “davidefa” plugin.
In a few moments he proposed me a modification of the original file in its part destined to the connection with Netatmo servers.
But my level of knowledge is so low that I don't know where to start to integrate it in the “davidefa” plugin.
Isn't there any expert on the forum so as not to waste the hours of work of Jachyn and Davide?
Best regards.
El_Viejo
Post by El_Viejo » Fri Jun 21, 2024 6:32 pm
I am still looking for a solution to the Netatmo server access problem. In the Netatmo forum, one of the users, has managed to successfully connect and insert the measurement data into his WordPress website.
https://www.blombergsbatsallskap.se/
He makes the PHP script available to the users.
My PHP programming knowledge is null. But one of the " savants " of this forum or Jachym himself could try to apply it to the Meteotemplate plugin.
Thanks in advance.
marcom78
Software: Meteotemplate
Post by marcom78 » Wed Jan 08, 2025 9:01 pm
Hi all
I'm trying to setup NetatmoNet pluging.
It works only for a few hours and after that it stop working
I think the issue is related to the token renewal
Does someone have identified a possible solution ?
Marco
