rain block: trouble with the new year
Post by meteoesine » Mon Jan 01, 2024 10:15 am
hello and happy new year
Have you also noticed that with the new year, starting today, if rain is recorded it no longer works?
if I delete the rain values it works instead
Is it just my problem or someone of you has encountered this problem?
tnx
Screenshot - 01_01_2024 , 11_07_22.jpg (4.92 KiB) Viewed 26514 times
Screenshot - 01_01_2024 , 11_07_55.jpg (21.92 KiB) Viewed 26514 times
Re: rain block: trouble with the new year
Post by davidefa » Mon Jan 01, 2024 11:47 am
It should be a division by zero error, this updated version should fix it.
rain_7.3.zip
(8.19 KiB) Downloaded 735 times
Post by alexvanuxem » Mon Jan 01, 2024 12:15 pm
hi all,
Happy new year to you all!
Thanks David!!!
(I was just looking to post the issue also, but you already fixed it!) :ugeek:
Post by meteoesine » Mon Jan 01, 2024 1:00 pm
TOP ! ;)
djpoppy
Station model: GW2000 - WS90
Post by djpoppy » Sat Feb 08, 2025 2:35 pm
Hi! I Have a problem with the rain block in the new year switch..
This is my website station: http://www.djpoppy.it
The gauge levels are over the 100% :geek: How can I solve it?
Alvaro Poggiani
Software: Meteobridge Pro2
Post by Alvaro Poggiani » Sat Feb 08, 2025 5:12 pm
Ciao Papavero,
non sono un esperto ma credo che il tuo problema si possa risolvere modificando i valori nelle impostazioni del blocco.
Sperando di riuscire a spiegarti cosa io intenda ti allego la schermata dei "miei" valori che per la Liguria dovrebbero andare bene (almeno per lo scorso anno è andata).
Magari poi la soluzione non è questa ma un precedente problema simile l'ho risolto in questo modo.
Ciao
alvaro
https://www.meteovarazze.it
Screenshot 2025-02-08 175735.png (194.1 KiB) Viewed 23906 times
djpoppy
Post by djpoppy » Thu Apr 17, 2025 12:07 pm
Screenshot 2025-04-17 alle 14.06.42.png (93.63 KiB) Viewed 14455 times
Thanks for the advice. I tried but nothing changed.
Alvaro Poggiani
Post by Alvaro Poggiani » Fri Apr 18, 2025 8:44 am
Probabilmente la mia domanda risulterà scioccamente superflua:
hai controllato di aver installato la versione 7.3 del blocco "Rain" ?
Come suggerito da Davidefa un po' di tempo addietro questa versione risolveva alcuni problemi.
Saluti cordiali
Alvaro
djpoppy
Post by djpoppy » Fri Apr 18, 2025 11:19 am
Yes, it's the latest version 7.3 I disabled the "Show comparison to average period if available." feature and now it seems to work better.
