Auto-updates
Auto-updates
Post by Jachym » Sun Oct 01, 2017 9:17 am
Hi guys,
clearly, what I need to know is:
- what percentage of people has problems with this
- what exactly happens
Then I will see the approximate percentage of users with problems and also can try to see if there is any pattern, if these users have something in common - same provider, same server configuration etc.
I would therefore like to ask everyone to check if the auto-updates/installations work and then let me know in this thread.
If the updates are working fine, just post "OK" - do not ignore this I need to also see for how many users it works, not just those who have probles.
If it does not work, just say "No" and if you can specify any more details it would be great.
Reinhard
Software: WeatherCat
Re: Auto-updates
Post by Reinhard » Sun Oct 01, 2017 9:19 am
OK, Block & PlugIn. :)
nitrx
Re: Auto-updates
Post by nitrx » Sun Oct 01, 2017 9:25 am
OK
http://apeldoornmeteo.nl meteotemplate multilangual by Jachym
http://www.apeldoorn.tk/weer/index.php Saratogatemplate by mulilangual
http://apeldoorn.tk/weer Cumulus template Dutch only by Steve/Sandaysoft
http://apeldoornmeteo.nl/pws/ Home Weather Station by Brian multilangual
MeteoTwischkamp
Station model: WH 1080 + RPI 3
Software: WeeWX 3.9.1
Re: Auto-updates
Post by MeteoTwischkamp » Sun Oct 01, 2017 9:27 am
Also OK for me, both Plugins and Blocks
"Deus mare, Friso litora fecit" (God created the sea, Frisians the coast).
Best Regards
Georg
barbuser
Re: Auto-updates
Post by barbuser » Sun Oct 01, 2017 9:29 am
OK here
Re: Auto-updates
Post by Johnny » Sun Oct 01, 2017 9:42 am
Okay for me as well, I use cPanel 11 with Namecheap
al60
Station model: Vantage Pro 2
Re: Auto-updates
Post by al60 » Sun Oct 01, 2017 9:52 am
I'm at OVH http://ovh.com.
I can not use automatic updates.
javigar66
Station model: Davis Vantage Pro II
Re: Auto-updates
Post by javigar66 » Sun Oct 01, 2017 10:09 am
It does not work.
I am on ovh.com and it does not work for me nor has it ever worked for me to automatically detect the latest version of each block or plugin
i_fiorentino
Re: Auto-updates
Post by i_fiorentino » Sun Oct 01, 2017 10:12 am
I don't know beacuse there wasn't any block or plugin to update.
stephane01
Re: Auto-updates
Post by stephane01 » Sun Oct 01, 2017 10:19 am
ok here
Re: Auto-updates
Post by Jachym » Sun Oct 01, 2017 10:23 am
OK, so far it is looking better than I expected, but I will need many more users to provide some feedback. Also it seems like there might be some common things amongst those for whom it does not work.
Pavel
Station model: TFA 35.1075 NEXUS
Re: Auto-updates
Post by Pavel » Sun Oct 01, 2017 10:30 am
OK
nikokara - BANNED
Re: Auto-updates
Post by nikokara - BANNED » Sun Oct 01, 2017 10:36 am
No (partial)
niko
Semtex
Station model: Davis Vantage Pro Plus 2
Re: Auto-updates
Post by Semtex » Sun Oct 01, 2017 10:41 am
All OK !!!!
Luc
Software: WeeWX
Re: Auto-updates
Post by Luc » Sun Oct 01, 2017 10:50 am
OK
Jeffm5690
Re: Auto-updates
Post by Jeffm5690 » Sun Oct 01, 2017 10:55 am
No. Used to at least show updates. Now all blocks and plugin are 0.0. Using inmotion host - they checked and can telnet your site and it is not blocked.
Re: Auto-updates
Post by MonyMony » Sun Oct 01, 2017 11:00 am
Works well for me.
Re: Auto-updates
Post by Jachym » Sun Oct 01, 2017 11:01 am
Jeffm5690 wrote: Sun Oct 01, 2017 10:55 am No. Used to at least show updates. Now all blocks and plugin are 0.0. Using inmotion host - they checked and can telnet your site and it is not blocked.
Yes, this one is particularly weird. Neither file_get_contents, nor cURL is able to load even a simple text file...
Re: Auto-updates
Post by meteoesine » Sun Oct 01, 2017 11:09 am
ok
Hugh
Re: Auto-updates
Post by Hugh » Sun Oct 01, 2017 11:23 am
OK for me.
Thomas
Re: Auto-updates
Post by Thomas » Sun Oct 01, 2017 11:41 am
Hi
not work for me (verification update blocks and plugins and update language, blocks impossible)
My web hosting told me to use a "user agent"; because meteotemplate.com rejects the commands "file_get_contents" without "user agent"...
Station Météo Alès: www.meteoales.fr
didoujm
Software: WEATHER DISPLAY
Re: Auto-updates
Post by didoujm » Sun Oct 01, 2017 11:45 am
pas de problème pour moi aussi
Didier
Brandon Barometer
Re: Auto-updates
Post by Brandon Barometer » Sun Oct 01, 2017 11:52 am
Ok block only, not plugin
stewart45
Station model: Ecowitt
Software: pws-dashboard
Re: Auto-updates
Post by stewart45 » Sun Oct 01, 2017 12:22 pm
ok
gand
Re: Auto-updates
Post by gand » Sun Oct 01, 2017 12:24 pm
Ok
