I have an issue with this block.
Temperatures Min and Max are false! See the picture
Same issue for 24h, today, 1h, yesterday
It semmes to be ok for the others (months, year...etc)
The only explanation I have for this is that for some reason data is not being saved to your db, but I would need to see what exactly is saved in the database
look at the Tmin and Tmax fields, there is a problem. The block works ok, it uses the data in the db. It is the data in the db that is not correct. How do you update your template? Which SW?
OK, but the problem is that when I looked at the raw data you are sending to the template, you are sending Tmax and Tmin as 21, do you have CRON job set for the realtime.txt?
This is really strange, did you make any modifications to either api.php or update/update.php? Because it looks like the template is for some reason using TMX and TMN as extra sensors
It seems to be fixed (for TMin it's OK, still waiting for the TMax), and hope it is
Well done Jachym, but beyond these solution, do you have an idea from where could come these issue?
once again thank you Jachym for your quick answer
