Intractive banner is stuck to blue sky
Lespius
- Station model: Davis VP2
Hi All,
My interactive banner is now blocked on "blue sky" for a couple of weeks.
I know it is linked to the metar specified in the general configuration. I have check my Metar plugin, it is up-to-date (code LSGG) http://www.meteo-cugy.ch/template/pages/metar/index.php
It looks like the information is no longer taking into account my Meteotemplate.
Does anyone noticed the same ?
Alain
Alain
mchd17
Re: Intractive banner is stuck to blue sky
now that you mention it, i haven't noticed mine changing from blue sky for a while. wonder if it's a https request issue
agallardo1980
Effectly @mchd17 It's a https issue,
Change this in /template/header.php (Line 172):
by this:
In my website it's working now
$urlMETAR = "http://tgftp.nws.noaa.gov/data/observations/metar/stations/".strtoupper($ICAO).".TXT";
$urlMETAR = "https://tgftp.nws.noaa.gov/data/observations/metar/stations/".strtoupper($ICAO).".TXT";
mchd17
Thanks!!
I also had to change code in /template/scripts/headerMetar.php
line 326 and 327
To this
line 326 and 327
//$no = "http://weather.noaa.gov/pub/data/x/stations/";
$no = "http://tgftp.nws.noaa.gov/data/x/stations/";Code: Select all
//$no = "https://weather.noaa.gov/pub/data/x/stations/";
$no = "https://tgftp.nws.noaa.gov/data/x/stations/";- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
it's perfect thanks to all
Lespius
Did the modifications, but no change.... Another idea ???
mchd17
Give it a bit of time, try control panel/clear metar cache
- livejerseyweather
I am having this same problem and have tried all of the fixes has anyone else got it working?
- dmgould
I made the code changes listed above, and mine started working properly. Go to the metar station you have entered into your main setup and make sure they are reporting correctly. I've had that issue in the past. If their sky report is not changing your banner won't change.
- magical46
I am having the same issue of the banner nor changing. I have just done the code changes as above and cleared the cache, may take some time to change, but looking at the METAR weather plugin it says "invalid METAR code EGLF" which is the correct code for Farnborough. Whatever airport I put in (I.e. heathrow, gatwick, Odiham) it says invalid code.
- dmgould
I just went to the NWS report for your METAR station. It is not reporting sky conditions at all. That seems to be the issue rather than your code changes.
ugo.call
- Station model: Davis vantage vue
Also I have the same problem I changed the code in /template/scripts/headerMetar.php, I also emptied the cache but it doesn't work, if I go to open the interactiveBanner.txt file I find written N / A while the Metar page works perfectly.
