Tides block stopped working
Alexandros
Station model: DAVIS Pro 2 Wireless
Post by Alexandros » Sat Jul 07, 2018 5:27 pm
For some reason it is almost a week that Tides_1.2 block stopped working and in its place Data N/A is only shown. I checked the related url in https://www.tide-forecast.com to see if their server is down but their site is working fine for my chosen location. So I guess that the process of decoding and stripping their data in the php meteotemplate tidesBlock file should be amended to probably include any changes that tide-forecast might have done in their page.
Any help on above?
hcorrin
Station model: Davis VP2
Re: Tides block stopped working
Post by hcorrin » Sat Jul 07, 2018 9:32 pm
Hi
just checked mine and I have the same but a cache file is created but the data in it is different to an older file I have on a backup
I also notice the plugin is giving the same error probably for the same reason
LOBWX
Station model: Ambient WS 1401-IP
Software: MeteoBridge
Post by LOBWX » Mon Jul 09, 2018 3:34 am
Same here - Data N/A
meteocaldas
Station model: OS WMR-88A
Post by meteocaldas » Mon Jul 09, 2018 9:14 am
Same here Data N/A.
TidesCache.txt is beeing created and updated but it looks like they have redesigned their html page and parsing data from there is not giving any results because their html code is somewhat different now.
I have been trying to fix the issue but my knowledge is too short for that and the result is always the same: no results :-)
Help, pleaseeee!
I had never imagined that there were so many fishermen visiting my site just looking for local beach weather, tides and moons :-)
stewart45
Station model: Ecowitt
Software: pws-dashboard
Post by stewart45 » Wed Jul 11, 2018 7:45 am
Same here, been down for a week now
Asobig
Software: Meteobridge (Red)
Post by Asobig » Wed Jul 11, 2018 8:33 pm
I think i figured out what changed in the html of the Tide-forcast website:
Do the following:
In tidesBlock.php change line 55 from:
preg_match('/<h1 class="tab">Tide Times for (.*?)<\/h1>/',$html,$matchesPlace);
to:
preg_match('/<h1 class="title is-4 has-text-primary has-text-centered">Tide Times for (.*?)<\/h1>/',$html,$matchesPlace);
Change line 71 from:
preg_match('/\<section class="tide-events not_in_print"\>(.*)?\<\/section\>/',$html,$matches);
to:
preg_match('/\<section class="section tides-content-table tide-events not_in_print is-imperial" >(.*)?\<\/section\>/',$html,$matches);
Change line 80 from:
$explodeDays = explode('<td class="date"',$predictionDiv);
to:
$explodeDays = explode('<th class="date "',$predictionDiv);
Change line 84 from:
preg_match('/rowspan="[0-9]">(.*?)<\/td>(.*?)$/',$explodeDays[$i],$matches);
to:
preg_match('/rowspan="[0-9]" >(.*?)<\/th>(.*?)$/',$explodeDays[$i],$matches);
Then the block is working again.
John B
Post by John B » Thu Jul 12, 2018 3:11 am
Thanks, Asobig, there's a bucket of salt water heading your way. ;)
It surely works for me.
stewart45
Post by stewart45 » Thu Jul 12, 2018 7:44 am
well done that man
xl1954
Software: API Meteotemplate
Post by xl1954 » Thu Jul 12, 2018 8:39 am
Hello all
After the correction from Absoblg, all is running.
Thanks a lot
Gus
Station model: Davis Vantage Pro 2+
Post by Gus » Thu Jul 12, 2018 1:52 pm
Followed Absobig's instructions and all is well. Had to make one change in line 71.
I had to change new line 71 from tide-events not_in_print is-imperial to tide-events not_in_print is-metric. This dependings what https://www.tide-forecast.com does not show as height, meters or feet.
- OR -
preg_match('/\<section class="section tides-content-table tide-events not_in_print is-metric" >(.*)?\<\/section\>/',$html,$matches);
Tide plugin can also be fixed by applying changes to ...
line 69
line 85
line 94
line 98
https://www.halethorpeweather.com/meteo ... /index.php
Thanks,
Gus
Davis VP2+, LabJack w/temp sensors & 1-Wire lightning counter on Trigkey G4 Mini PC, 12th Gen Intel Alder Lake N95 Processor, 16GB SDRAM, and 500GB SSD, Windows11
meteocaldas
Post by meteocaldas » Thu Jul 12, 2018 6:38 pm
Asobig wrote: Wed Jul 11, 2018 8:33 pm I think i figured out what changed in the html of the Tide-forcast website:
Do the following:.....
Hi Asobig,
Thank you sooooo much!
Tide block is working perfectly again, and now all the fishermen in my area will be thanking you too :-)
LOBWX
Post by LOBWX » Thu Jul 12, 2018 11:15 pm
For the life of me I can't get this block to work again? I installed the 1.3 block that was just updated in the blocks section http://www.meteotemplate.com/web/blocks.php
The block is caching the data from https://www.tide-forecast.com/locations ... des/latest
Im stumped???
BlueBear
Software: WeeWx
Post by BlueBear » Fri Jul 13, 2018 2:02 am
In case you hadn't noticed, your tide plugin isn't working either!!!
Neither is mine :(
LOBWX
Post by LOBWX » Fri Jul 13, 2018 3:05 am
I tried what Gus had posted but still the Block nor the Plugin are working :?:
Alexandros
Post by Alexandros » Fri Jul 13, 2018 3:41 pm
All is fine again. Asobig, thank you for your effort and especially your time.
dtwrlewis
Station model: Ecowitt HP2553
Software: Ecowitt GW1100
Post by dtwrlewis » Fri Jul 13, 2018 6:23 pm
This worked for me
Gus wrote: Thu Jul 12, 2018 1:52 pm Followed Absobig's instructions and all is well. Had to make one change in line 71.
- OR -
line 69
line 85
line 94
line 98
Thanks,
Gus
LOBWX
Post by LOBWX » Sat Jul 14, 2018 1:56 am
So I have tried to get this Tides Block to work again on two different servers with absolutely no luck. One is my paid hosted server and the other is on my PI3B+.
If someone would not mind posting their entire working tidesBlock.php here so I could try using it to rule out any syntax errors on my part. I would appreciate it.
Nevermind I got it to work again
~Bob~
hcorrin
Post by hcorrin » Tue Jul 17, 2018 9:39 pm
the block is working ok for me after the update, but when I tried the changes in the plugin, the page loads but no graph or data is showing and if metric is used instead of imperial I get data N/A
http://www.hc-iom.co.uk/template/plugin ... /index.php
dtwrlewis
Post by dtwrlewis » Thu Dec 06, 2018 2:19 pm
Data not available again.
Have they changed their formatting again?Anyone else having this problem?
John B
Post by John B » Thu Dec 06, 2018 10:29 pm
All fine here (Thu. 2018-12-06 22:30 UTC).
livejerseyweather
Post by livejerseyweather » Mon Oct 07, 2019 6:31 pm
I think the formatting has changed again as all appears to be offline. Any ideas anyone?
stewart45
Post by stewart45 » Wed Oct 09, 2019 11:51 am
same problem here
