Anyone create a CoVID-19 Block to share?
Post by MonyMony » Thu Mar 12, 2020 1:03 pm
Hi all,
I would like to add a CoVID-19 block to my site that just shows the Johns Hopkins University map (https://www.arcgis.com/apps/opsdashboar ... 7b48e9ecf6) but just don't have time to put this together. Wondering if anyone has done this and if they wish to share.
Thanks and stay safe!
Jay
Re: Anyone create a CoVID-19 Block to share?
Post by andyk1 » Fri Mar 13, 2020 4:32 pm
MonyMony wrote: Thu Mar 12, 2020 1:03 pm Hi all,
Jay
I've considered doing just that using the John Hopkins University model (same as your link) It would be a simple html tag but the problem I ran into is that the link is only good for one time. Updated links must be updated manually which defeats the purpose. A link I saved a few weeks ago still reads that dates total only. Not sure how they are doing it other than finding the new link at a news site or how often it is updated. Deleting cache and cookies does no good also. Maybe it's something I'm doing wrong.
Edit: I tried the following line in html format in the text and greeting blocks but it does not work.
<AHREF="https://www.arcgis.com/apps/opsdashboard/index.html#/bda7594740fd40299423467b48e9ecf6/">Corona Virus Map</A>
Asobig
Software: Meteobridge (Red)
Post by Asobig » Fri Mar 13, 2020 9:41 pm
There is a daily file with the raw data available at:
https://github.com/CSSEGISandData/COVID ... ly_reports
Maybe someone can make a block with Highcharts and the csv files....
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Sat Mar 14, 2020 10:23 am
Hello
Coronavirus, I created this Personal Block
Good use
update new new version version 1.7
coronavirus.7z
(100.74 KiB) Downloaded 1288 times
Post by MonyMony » Mon Mar 16, 2020 9:17 pm
Hello José,
Thank you for posting this. One question I have is I see the block is referencing /homepage/blocks/coronavirus/imgs/coronavirus.png. Is this meant to be just a static image or is this something that updates from time to time? Just curious as I have not had enough time to explore.
Thanks!
Jay
Jolumarali
Software: WlIP
Post by Jolumarali » Tue Mar 17, 2020 7:26 am
Hello Jay
It is a clickable image, with a link to the coronavirus map.
I made a modification on version 1.7, with just an info to click on the image.
Hoping that all of its red dots will disappear quickly.
In the "more" information on the origin of the data and the precautions for our health and the people around us.
Being French, sorry, I use a translator as much here as for the Block.
Version 1.7
coronavirus.7z
(26.67 KiB) Downloaded 962 times
Post by MonyMony » Tue Mar 17, 2020 12:18 pm
Hi José Luis,
Thank you for the clarifications and for sharing this block. I too hope these red dots start disappearing soon as this is getting crazy. Your English translations are very good as I would not have even known had you not mentioned the translator. I work for a company that is headquartered in Luxembourg so while je ne parle pas français I'm used to finding ways to communicate across languages. :)
Please stay safe!
Jay
Post by MonyMony » Wed Mar 18, 2020 1:27 am
Hi José Luis,
Thanks again for the block. I've added it to my site and looks good. I had one small issue where the map image would not display but was a simple fix to drop the leading "/" from the image path.
src="/homepage/blocks/coronavirus/imgs/coronavirus.png
changed to
src="homepage/blocks/coronavirus/imgs/coronavirus.png
I hope we don't need to display this block too long.
Jay
Jolumarali
Software: WlIP
Post by Jolumarali » Wed Mar 18, 2020 6:46 am
Hello Jay
Modification made
perfect
take care of you
mchd17
Post by mchd17 » Sat Mar 21, 2020 2:58 pm
i am using this block too, thanks for sharing!!
cw3beck
Post by cw3beck » Sun Mar 22, 2020 8:06 am
Thanks for sharing and have included it on my site as well.
lemimi
Post by lemimi » Sun Mar 22, 2020 10:50 am
Bonjour,
Merci José Luis, merci à tous, moi aussi je viens d'inclure ce bloc.
Portez-vous bien et au plaisir. . . Michel
PS: Cette fois-ci José Luis, tu n'auras pas besoin de te servir de ton traducteur favori !
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Mar 22, 2020 12:01 pm
Bonjour Michel
Pour vous evitez de faire la traduction du BlocK.
ci joint la version 1.8 en français.
Prenez soin de vous ainsi qu'a toute votre famille et amis.
coronavirusFr.7z
(30.11 KiB) Downloaded 828 times
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Mar 22, 2020 4:29 pm
Pour toi michel
Petite modif effectuée dans le zip 1.8
homepage/blocks/coronavirusFr/imgs/restez.png
meteolopik
Station model: Davis Pro 2 Plus
Post by meteolopik » Tue Mar 24, 2020 12:19 pm
I have incorporated (and edited it to local needs) this block too. Thank you so much for sharing, stay healthy all!!
I enclosed the edited zip file for other Dutchies to use.
coronaNL.zip
(380.01 KiB) Downloaded 1015 times
scadie
Station model: Davis Vantage Pro
Post by scadie » Sun Mar 29, 2020 8:30 am
Hi Everyone,
Thank you for that block, it's working perfectly. I have a small question:
What is the code i need to modify to be able to expand the "more" by default ? I will like the block to display all the information without neede to press more each time.
Thank you for your help.
Sylvain Cadieux
scadie@scadie.com
Meteo Saint-Hubert: http://www.meteosaint-hubert.com
lemimi
Post by lemimi » Sun Mar 29, 2020 10:55 am
Bonjour,
C'est peut-être ce que vous cherchez:
https://www.lemimi.fr/template/indexDesktop.php
dans ce cas, si cela vous intéresse c'est ici:
https://www.lemimi.fr/download/coronavirusFrBlock.zip
Renommer votre ancien fichier coronavirusFrBlock.php en coronavirusFrBlock-ori.php, par exemple avant d'y mettre celui-ci plutôt que de l'écraser.
Plus facile de revenir en arrière.
Au plaisir et bonne journée... Michel
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Mar 29, 2020 11:08 am
Bonjour
nouveau Block covidFr
Suivi des patients Covid-19 en France
Prenez soins de vous
covidFr.7z
(25.85 KiB) Downloaded 1441 times
lemimi
Post by lemimi » Sun Mar 29, 2020 1:47 pm
Bonjour,
Merci pour ce nouveau lien que je vais m'empresser de diffuser autour de moi.
Cela devrait rassurer pas mal de personnes dans mon village qui sont inquiètes de ne pas savoir comment cela se propage dans notre département.
Encore merci et portez-vous tous bien... Michel
Meteopomezia
Software: Wview
Post by Meteopomezia » Sat Apr 04, 2020 11:03 am
Goodmorning everyone
I modified the blockade for Italy
Hopefully these red dots will decrease strength guys. :oops:
coronavirusIT.zip
(171.12 KiB) Downloaded 1226 times
F1SKF
Station model: HP2550
Post by F1SKF » Sat Apr 18, 2020 7:17 am
Bonjour à tous,
J'ai un peu de difficulté avec ces blocs Covid-19.
Il y a bien 2 blocs disponibles.
- un mondial
- et un pour le suivi en France.
Serait-il possible d'avoir le lien pour charger ces deux blocs complets en Zip ?
Par avance merci
Hervé
meteo88.pecouba.fr
Ironside1977
Station model: Davis Vue
Post by Ironside1977 » Sun Apr 19, 2020 8:49 am
Someone has the block for Spain???
I see FR,CZ and IT.
Thanks....
Jolumarali
Software: WlIP
Post by Jolumarali » Sun Apr 19, 2020 10:13 am
Mire la traducción, puede haber algunos errores.
Pour les zips coronavirus français regarder les téléchargements ci-dessus
covidEs.7z
(98.89 KiB) Downloaded 972 times
Ironside1977
Post by Ironside1977 » Sun Apr 19, 2020 12:50 pm
Jolumarali wrote: Sun Apr 19, 2020 10:13 am Mire la traducción, puede haber algunos errores.
Muchas gracias por todo. :D
lemimi
Post by lemimi » Sun Apr 19, 2020 2:52 pm
Bonjour José Luis,
Jolumarali wrote: Sun Apr 19, 2020 10:13 am Pour les zips coronavirus français regarder les téléchargements ci-dessus
J'ai aussi trouvé en français : https://dashboard.covid19.data.gouv.fr/
Pour l'Allier: https://dashboard.covid19.data.gouv.fr/departements/03
J'ai mis ce lien à la place de https://mapthenews.maps.arcgis.com/apps ... 43e14a548c dans le fichier covidFrBlock.php
Au plaisir et bon dimanche... Michel
