I have noticed that the graphics in the monthly/annual reports do not work for me. The data is displayed, but no graphics are drawn, the space for the graphics simply remains empty.
For example:
https://www.buedelsdorfwetter.de/templa ... ate=2020/5
Clicking on the respective symbols does not create the graphics.
The graphics on Live-Section are working, only on the reports-section it doesn't work.
PHP version on the server is 7.4, tried PHP version 7.1, no change.
What could be the reason?
Thanks for help
Michael
Graphics on the monthly/yearly reports don't working (SOLVED!)
xray77
- Asobig
- Station model: Davis Vantage VP2+
- Software: Meteobridge (Red)
Re: Graphics on the monthly/yearly reports don't working
There is a Javascript error:
VM74:86 Uncaught SyntaxError: Invalid or unexpected token
at eval (<anonymous>)
at jquery.min.js:2
at Function.globalEval (jquery.min.js:2)
at m.fn.init.domManip (jquery.min.js:3)
at m.fn.init.append (jquery.min.js:3)
at m.fn.init.<anonymous> (jquery.min.js:3)
at m.access (jquery.min.js:3)
at m.fn.init.html (jquery.min.js:3)
at Object.<anonymous> (jquery.min.js:4)
at j (jquery.min.js:2)
It is in this part:
You could try to change the site language to english and see if the error stays. I changed my site to german and the graphs work.
Did you change the file 'de.php' or so?
at jquery.min.js:2
It is in this part:
xray77
Hello Asobig,
I switched the Language to British English or an other language and it works! I haven't edited the "de.php" but I have installed the block "language switcher".. Is it possible that this makes the error?
When I switched back to German language, it doesn't work again.., that's bad..
I would prefer the German language, cause it's my native language...
Watt can I do to resolve it?
Thanks and best regards
Michael
Michael
- Asobig
I didn't even knew there was a block that did that...
You could try to remove that language switcher block. In the right top corner users can change the language without the need of a block (you click the wheel above the questionmark). That function is at this moment not working on your site. Maybe that is why there is an error?
xray77
Hello Asobig,
have removed the block Language-Switcher.. (delete this block on my server, there's no trash in block-setup for it).. No changes, in German language the graphics don't work..
It seems so, the original "de.php" is changed by everything.. Is it possible to send me your original "de.php" per private message here to try it out?
The language-switcher as you described on top of my site works at me here, can switch the languages there and restore to default. have tried this, but the graphics (JS-Script-error) persists..
best regards
Michael
best regards
Michael
- Asobig
Hey Michael,
I see your language switcher (top right corner) is working now.
My de.php file is in the attachement.
Greetings,
Gerard
Greetings,
Gerard
- de.php.zip
- (21.93 KiB) Downloaded 577 times
xray77
Hello, Asobig,
Yes! It now works in german too, great!
I never would have looked for the reason for this error at this cause..., thank you very much for your help!
Nice weather in the Netherlands, but right now the sun is coming out here too...
Best regards
Michael
Best regards
Michael
- Asobig
Re: Graphics on the monthly/yearly reports don't working (SOLVED!)
Nice to see that it works!
The weather is great, maybe a little bit to much wind.
Greetings,
Gerard
Greetings,
Gerard
