Hello all!
I’m not sure if this question has been asked before but I am wondering if some php genius would be able to add UV to the drop-down options in the Interactive graph block. I have tried it myself but I’m not enough educated on php to make it actually work properly.
UV in Interactive Graph block
- meteolopik
- Station model: Davis Pro 2 Plus
Re: UV in Interactive Graph block
Added uv sensor
- interactiveGraph_11.2.zip
- (8.04 KiB) Downloaded 625 times
- meteolopik
Thanks for the effort, unfortunately it’s still not showing the graph line. Maybe it’s pulling data from the wrong database? Or am I missing something else?
Yes, I forgot to check on my 'online' site, I corrected the table name.
You have to run the block setup again if you want to set the uv graph color ( or it will be drawn in default color )
- interactiveGraph_11.2a.zip
- (7.82 KiB) Downloaded 597 times
- meteolopik
- meteolopik
One more question. Do you know if it is possible to merge both values (solar and uv) in one overview? Just as in temperature and apparent temperature.
Yes it is possible ( this is only a preview, not all options already implemented, but usable ).
You have to run the block setup and enable 'show uv graph' option.
Changelog:
- refactored source
- added 2 axis graphs
- grouped sensors ( differently )
- added PP, SM, ST graphs
- preview release
Please report malfunctioning and other suggestions
Changelog:
- refactored source
- preview release
- interactiveGraph_11.3p.zip
- (8.61 KiB) Downloaded 627 times
- meteolopik
Wow, this is exactly the genius trick I was looking for. This really made the block more powerful if you ask me. Thanks a million!!
