ForeCast NL (knmi & buienRadar) not working anymore?
WouterK
Software: WeatherCat
Post by WouterK » Sat May 22, 2021 6:31 am
I am not getting any forecast informatie by the ForecastNL block. Both knmi and buienRadar forecast is not shown anymore. Did not change anything in the config and the block has not changed either.
Is this a known issue which is easy to solve?
Thanks.
Wouter
Re: ForeCast NL (knmi & buienRadar) not working anymore?
Post by davidefa » Sat May 22, 2021 2:33 pm
This should fix the buienRadar... but I can't ( for the life of me ) fix the knmi ( there are two ftp url, which are correct, but both download fail )
forecastNL_2.1a.zip
(5.74 KiB) Downloaded 422 times
WouterK
Post by WouterK » Sat May 22, 2021 3:45 pm
Thank you for the quick fix!
At least one of them is working ;-) so will be using buienRadar.
Removed the selection box so there will be no empty block.
As for knmi data, maybe this one can be used : https://weerlive.nl/weer.php?plaatsnaam=Amsterdam
Thanks again.
Wouter
