nwsForecast Block Error
enephler
Post by enephler » Mon Feb 05, 2018 11:52 am
Hello... There seems to be an issue with the nwsForecast block forecast temperatures, they are 12 hours off.
Meteotemplate NWS Error.jpg (210.96 KiB) Viewed 6009 times
NWS Correct.jpg (180.99 KiB) Viewed 6009 times
Re: nwsForecast Block Error
Post by Jachym » Mon Feb 05, 2018 12:22 pm
the problem is in the fact that the block uses HTML scraping and given how often NWS changes their website it is pointless trying to fix this.
What I need is some machine readable format - JSON, XML etc. so if anyone knows about something it would be great. Otherwise it is just fixing something that is likely to break in couple of weeks again
enephler
Post by enephler » Mon Feb 05, 2018 12:27 pm
Not sure if this is what you're looking for, but it's NWS's XML link from the same forecast page...
https://forecast.weather.gov/MapClick.p ... tType=dwml
P.S. The text/detailed forecast under the "More" link is correct, just not the icon forecast.
nineback
Software: WeeWX
Post by nineback » Mon Feb 05, 2018 12:46 pm
Mine is working fine here.
Screenshot 2018-02-05 06.43.49.png (117.88 KiB) Viewed 6000 times
enephler
Post by enephler » Mon Feb 05, 2018 12:49 pm
Are you using "station" or coordinates in the block setup?
I'm using station.
nineback
Software: WeeWX
Post by nineback » Mon Feb 05, 2018 12:53 pm
Station.
