Year normals - frost analysis
T-man
Post by T-man » Fri Mar 16, 2018 9:56 pm
http://veikkola-weather.com/template/pl ... alysis.php
For some reason just blank page... What shall be done?
-Timo
Re: Year normals - frost analysis
Post by Dehatter » Fri Mar 16, 2018 10:05 pm
How are you accessing the page?
I do not see frost analyses in your menus.
T-man
Post by T-man » Sat Mar 17, 2018 7:12 am
Link to index page. http://veikkola-weather.com/template/pl ... /index.php
Menu Station... Extended Analysis...
-Timo
Post by Dehatter » Sat Mar 17, 2018 8:49 am
Thank you.
I installed the plugin and it works for me.
Since there is no setup, and no chance of losing any data, I would recommend that you delete the plugin from your server and then copy it back to the plugin folder. If it does it again, then I would download the plugin again and repeat.
http://www.tempestasvigilate.com/templa ... /index.php
It should only take about 2 or 3 minutes.
Must be some kind of corruption in your frostAnalysis.php file. It seems it is missing most of the code.
T-man
Post by T-man » Sat Mar 17, 2018 1:40 pm
It seems to be server side problem. No idea how to fix it though...
[17-Mar-2018 15:32:31 Europe/Helsinki] PHP Fatal error: Allowed memory size of 33554432 bytes exhausted (tried to allocate 32 bytes) in /home/xxxxx/public_html/template/scripts/functions.php on line 267
-Timo
Post by Dehatter » Sun Mar 18, 2018 8:46 am
Me either. When I try and see the page it is pretty empty:
Yours:
Mine:
I have no clue.
Post by Jachym » Sun Mar 18, 2018 8:55 am
T-man wrote: Sat Mar 17, 2018 1:40 pm It seems to be server side problem. No idea how to fix it though...
-Timo
YOu have a relatively very low php memory limit set on your server and it cant handle the amount of data you already have in the db
T-man
Post by T-man » Sun Mar 18, 2018 11:45 am
Since I'm running pages on hosted server, what shall I propose to admin?
Post by Jachym » Sun Mar 18, 2018 4:47 pm
increasing the PHP memory limit
T-man
Post by T-man » Sun Mar 18, 2018 8:02 pm
Works:
add
ini_set('memory_limit', '64M');
to frostAnalysis.php
Post by Jachym » Mon Mar 19, 2018 7:11 am
This will not work on all servers. For example I use external webhosting and the memory available depends on the monthly fee so they obviously block this so that people cannot change this in scripts. It depends on your webhosting but these ini_set parameters can be blocked so that it cannot be changed by a script
T-man
Post by T-man » Wed Mar 21, 2018 5:19 pm
Piece of advice from host support was actually to use cpanel and increase allocated memory with php.ini editor. Works.
Post by Jachym » Wed Mar 21, 2018 7:31 pm
Good :-)
Although it has to be said this is not a universal solution. Some providers (like mine) will not allow you to do this, because higher memory means higher plan and higher price.
