How do I install Outlook in the header block?
The weather forecast in /html/meteo pages/forecast ?
That does not work so in header block http://www.luetjenburg-wetter.de/meteo/ ... /index.php
What do I have to do?
Thank You
Header Block
- John B
Re: Header Block
Hello, Piddy,
I'm assuming that you want the header to contain the outlook block.
In your home page setup (click on your management icon to get there) you will find a section labelled "Header block".
I use ssgauges in mine (you'll see it if you have a quick look at my site). In yours you will need to type the name of the outlook block. Don't forget to scroll to the bottom and save it.
Have you downloaded the "outlook" block from Jáchym's site? If you haven't then do so and install it on your site in the normal manner. Then try again.
Piddy
Re: Header Block
Hello and thank you,
the outlook is embedded in version 17, and I'd like to have them in the header block.
Piddy
Re: Header Block
Hey,
like this on the mainsite.
- forecast.jpg (23.5 KiB) Viewed 8844 times
- dmgould
Re: Header Block
This is the forecast block you are showing not the outlook block. I'm confused when you say it is embedded in 17. Both of these blocks need to be downloaded from Jachym's site and installed. Then you can place them on your page where you want them to appear using the block name.
- John B
Re: Header Block
Thanks for posting the screen shot, Piddy, as it appears that I was misunderstanding your need (confusion with the words outlook and forecast).
Also thanks to dmgould for his explanation, which to me is correct.
