Header Block
Posted: Thu Jul 05, 2018 11:18 am
by Piddy
How do I install Outlook in the header block?
The weather forecast in /html/meteo pages/forecast ?
That does not work so in header block
http://www.luetjenburg-wetter.de/meteo/ ... /index.php
What do I have to do?
Thank You
Re: Header Block
Posted: Fri Jul 06, 2018 2:30 am
by John B
Hello, Piddy,
I'm assuming that you want the header to contain the outlook
block.
In your home page setup (click on your management icon to get there) you will find a section labelled "Header block".
I use ssgauges in mine (you'll see it if you have a quick look at my site). In yours you will need to type the name of the outlook
block. Don't forget to scroll to the bottom and save it.
Have you downloaded the "outlook"
block from Jáchym's site? If you haven't then do so and install it on your site in the normal manner. Then try again.
Re: Header Block
Posted: Fri Jul 06, 2018 10:33 am
by Piddy
Hello and thank you,
the outlook is embedded in version 17, and I'd like to have them in the header block.
Re: Header Block
Posted: Sun Jul 08, 2018 4:13 pm
by Piddy
Hey,
like this on the mainsite.
Re: Header Block
Posted: Sun Jul 08, 2018 10:56 pm
by dmgould
This is the forecast block you are showing not the outlook block. I'm confused when you say it is embedded in 17. Both of these blocks need to be downloaded from Jachym's site and installed. Then you can place them on your page where you want them to appear using the block name.
Re: Header Block
Posted: Mon Jul 09, 2018 12:16 am
by John B
Thanks for posting the screen shot, Piddy, as it appears that I was misunderstanding your need (confusion with the words outlook and forecast).
Also thanks to dmgould for his explanation, which to me is correct.
Re: Header Block
Posted: Mon Jul 09, 2018 6:07 pm
by Piddy
Thank You.
