in plugin StationCompare i setup the value "EDDN" for Metar.
If i look at Compare the plugin showes me: Data N/A
The error comes, because the variable $dataRaw in compareMETAR.php is empty.
Has someone an idea what the problem could be?
Michael
StationCompare No Data from Metar
gand
Re: StationCompare No Data from Metar
Hi Michael
Did You fix this?
Gert
Did You fix this?
Gert
ph2
Same problem: Correct Code LOWS, shown is "Data N/A". On the configuration page is the heading “SNOW-SETUP”. In the plugin-setup-overview, “Create settings” remains unchanged instead of “Edit settings”.
