I have this icon showing at the top middle of my warnings block.
I do not know if it is suppose to be there or not, or if it means I have a setting incorrectly made.
I have my test to display when there is NO warning set to show no text.
Anyone else notice it?
WarningsUS Block strange icon
- BobW55
- Station model: Davis Pro2
Davis Vantage Pro2 wired
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
nineback
- Software: WeeWX
Re: WarningsUS Block strange icon
I have the same. I always assumed it was the icon for the warning block.
- BobW55
I looked at the warnings block .PHP file, but could not find anything referencing the ICON.
I'll keep looking. Want the block to be totally blank unless there is a warning.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
- BobW55
Found at about line 136 in the file "warningsUSRegionsBlock.php"
<span class="mticon-warninggeneral" style="font-size:1.6em"></span><br>
I just remarked it out. See what happens now. wish there was a way to trigger a test warning.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
- John B
Hello, Bob,
I cannot speak about the U.S.ofA. warnings, but I can about the AU equivalent.
Now, you've been around the traps for a while, so I'm probably talking through my hat - but, just in case.
On the AU warnings set-up page there is an option to show or not show the icon. It's at the bottom in the attached image.
Like I say, "just in case", please don't 'burn' me.
- AUwarnings_set_up.jpg (59.98 KiB) Viewed 7530 times
nineback
- Software: WeeWX
THE USA warning has the same option to turn off the icon. Good catch.
- BobW55
Good catch indeed.
I will go back and change my REM, and check the block settings.
Solar/UV sensors
Sky Cam
Ham radio K8pos
Solar/UV sensors
Sky Cam
Ham radio K8pos
