warnings us regional wont display
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Wed Dec 02, 2020 4:32 pm
All I can ever get is No Current Advisories watches or warnings ver 7.0
The Cache folder and file does create, I have checked permissions, Im currently useing FLC071 but have switched to a zone code that has Advisories and still nothing goes in the cache file
I have copyed another users Advisorie data to the warningsUSRegions.txt file removeing the double brackets [ ] and that advisery will display in Meteoplate
I have checked the path to the xml data "https://alerts.weather.gov/cap/wwaatmge ... FLC071&y=0" and the xml is pulled up
I am showing no errors in the php log
anyone have any idea why the data does not write to the warningsUSRegions.txt file
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
spd2612
Re: warnings us regional wont display
Post by spd2612 » Sun Dec 13, 2020 1:42 pm
Well
It looks like im not going to get any help here
Maybe I will go a different way with this
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Fri Dec 18, 2020 2:02 pm
Wish I has some suggestions. My use of this block works as expected. Certainly sounds like a permission issue. If your provider has detailed logs for your site access, do those pick up anything unusual when this block runs?
spd2612
Post by spd2612 » Fri Dec 18, 2020 3:04 pm
I have my own server banks so i have access to all the logs
I get no errors in php or iis logs
I am able to get the NWS files to run in a blank block
NwsAlerts works a little different and even though it was written for Saratoga it will run stand alone
I still have a little work to do on it but NWSALERTS is working
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Fri Dec 18, 2020 4:45 pm
spd2612 wrote: Fri Dec 18, 2020 3:04 pm NwsAlerts works a little different and even though it was written for Saratoga it will run stand alone
Wait, you managed to get the Saratoga NWS Alerts working in Meteotemplate? I've been wanting to do that for a long time as the warningsUSRegions blocks does not handle multiple zones well and shows duplicate warning messages. The NWSAlerts block from Saratoga has a array that eliminates this duplicate entry option. I would certainly be interested in how you did this as from my perspective this would be the better way to go.
Post by MonyMony » Fri Dec 18, 2020 4:49 pm
BTW, when I try to go to your site I get a big warning message:
Screen Shot 2020-12-18 at 11.48.48 AM.png (168.06 KiB) Viewed 48479 times
spd2612
Post by spd2612 » Fri Dec 18, 2020 5:26 pm
That should be fixed
Never updated my signature url to https after i secured all my sites
And yes if you look at my site now there is a warning I am still working on the details page but it will load I am using nwsalerts and calling it from a blank block there is some changes needed in the nwsconfig file needed
It all runs from the blank block folder which i renamed
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Fri Dec 18, 2020 9:33 pm
Yes, it is fixed and I can get to your site now without a big security prompt.
That is awesome using the Saratoga NWSAlert code. So would you be willing to share? I can offer up my fixes for the USRADAR (viewtopic.php?f=56&t=1984) and the other updates I did for that block to show the newer satellite images as a trade. You can see them on my site to see what I did.
spd2612
Post by spd2612 » Fri Dec 18, 2020 9:55 pm
Yes but I am still working on it
I can give you what i have but it will be tomorrow
I have the summary link reactivated but it adds to the link in summary so you can get to the summary but but in the summary those links get broken
I would also rather have them open in a new page but have not got that yet
Im just a little busy tonight ill pm tomorrow
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Fri Dec 18, 2020 10:55 pm
No rush at all. I've waited years for this so I can wait longer. :)
spd2612
Post by spd2612 » Sat Dec 19, 2020 4:38 pm
PM SENT
MY menuBlock(radarUS) Quit working yesterday
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Sat Jan 02, 2021 1:45 am
@spd2612, I have not been ignoring you. For some reason all of my PM replies on this forum are stuck in the OUTBOX. If someone else have a way to resolve this please let me know.
I did take the code you posted for the Saratoga National Weather Service Alerts and made some modification to better integrate it into Meteotemplate. The updated block can be downloaded by going to https://www.cecilweather.com/weather/ce ... s_v1.1.zip and installed just like any other Meteotemplete block.
To make this work, the nws-alerts-config.php file needs to be directly edited. I did the following updates in this file to make this work well within Meteotemplate:
  • $myZC - with the wanted zones by getting codes from alerts.weather.gov
  • $ourTZ - with the current time zone
  • $cacheFileDir - directory with the alerts cache is stored.
  • $icons_folder - directory for the icons are stored
  • $blockpath - this is something customized for Meteotemplete. This is the path where this block resides on your website.
  • $alertURL - path to where the nws-details.php file is located
  • $summaryURL - path to where the nws-summary.php file is located
The rest of the variables should also be checked and adjusted as needed. Particularly if you are going to retrieve more than a couple zones then you should set the $noCron to FALSE and setup a CRON job. If anyone is reading this wondering how all this works, please check out the README file included in the zip as it contains all of the details from Saratoga-weather.org who get all of the credit for developing this script. I also left my settings in the nws-alerts-config.php file to be used as a guide. Hope this helps!
You can view the updates in action by going to my site - https://www.cecilweather.com. I would say PM me if you have questions but I might not be able to reply back privately.
cw3beck
Post by cw3beck » Sat Jan 02, 2021 7:36 pm
Thanks for the work on this block! I'm going to give it a try. BTW, I love the layout of your website!
John B
spd2612
Post by spd2612 » Sat Jan 02, 2021 8:19 pm
MonyMony wrote: Sat Jan 02, 2021 1:45 am @spd2612, I have not been ignoring you. For some reason all of my PM replies on this forum are stuck in the OUTBOX. If someone else have a way to resolve this please let me know.
Thanks alot that works like I was eventually going to make it go, I am going to add a link to the log file also
Also the Radar block is fixed thanks to your little fix
Anyone else should also edit the NWSBlock.php, for your own discription at line 32 after "Advisories, Watches and Warnings"
Davis Pro 2
Meteobridge Pro2
GW 2000
cw3beck
Post by cw3beck » Sat Jan 02, 2021 10:01 pm
I can't seem to find the fix that is referenced for the US Radar block in the forum. I am interested in applying the fix as well. Thanks.
John B.
spd2612
Post by spd2612 » Sat Jan 02, 2021 10:06 pm
See here for fix for radar
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Sun Jan 03, 2021 2:05 am
Glad the updates are useful and thanks for adding the reminder about updating the NWSBlock.php as I forgot to mention that.
I am waiting for the NWS to finish their radar upgrades before doing more work with the US Radar Block as there are some comments that some of the missing radar links might be coming back online as some point. Hopefully something later this month.
Jay
Post by MonyMony » Sun Jan 03, 2021 7:10 pm
cw3beck wrote: Sat Jan 02, 2021 7:36 pm BTW, I love the layout of your website!
John B
Thank you John!
spd2612
Post by spd2612 » Tue Jan 05, 2021 5:12 pm
How did you get the satelight to display i only get still jpg on my usradar
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Tue Jan 05, 2021 9:01 pm
spd2612 wrote: Tue Jan 05, 2021 5:12 pm How did you get the satelight to display i only get still jpg on my usradar
Sorry not much time to give a detailed explanation but if you look at the section for 'radarUSNationSelector" you will see all of the link options. Some of this no longer work so adjust as you want. I'll try to give more details later this week. One thing to be aware of with this block is these links are repeated four times (I think it is four) in the code so make sure any updates you do is done for each display option. Not sure why it was setup that way.
Jay
radarUSBlock.php 20210105.zip
(7.36 KiB) Downloaded 858 times
spd2612
Post by spd2612 » Mon Jan 11, 2021 8:52 pm
Jay
Ok found the links and changed your mid atlantic to south atlantic https://cdn.star.nesdis.noaa.gov//GOES1 ... 00x600.gif
It all works but I dont see where I can default it to South Atlantic I have to manually select it when I go to the page
I tried entering Visible Satellite - South Atlantic in the CP for Default national radar image but still wont default it
My line
https://cdn.star.nesdis.noaa.gov//GOES1 ... 00x600.gif" <?php if($nationalDefault=="visible"){ echo "selected"; }?>>Visible Satellite - South Atlantic</option>
john M
Davis Pro 2
Meteobridge Pro2
GW 2000
Post by MonyMony » Mon Jan 11, 2021 9:13 pm
You'll need to explore but look at https://cdn.star.nesdis.noaa.gov//GOES16/ABI/SECTOR/ and hunt around. It is not easy! I think the one you need is this: https://cdn.star.nesdis.noaa.gov//GOES1 ... 00x600.gif
Other things can be found in https://www.nesdis.noaa.gov/content/goe ... ite-images but finding the 'current version' is a challenge.
spd2612
Post by spd2612 » Mon Jan 11, 2021 9:23 pm
I was editing my post when you replyed
Davis Pro 2
Meteobridge Pro2
GW 2000
