moonPhase Block Icons
Posted: Mon May 31, 2021 3:21 pm
by psper
Hi all,
I use moonPhase Block but moon icons are correct only for South Hemisphere.
I think that for North hemisphere they are wrong.
It is diferente between north and south hemisphere.
Do you know how to correct this?
Thanks in advance,
Paulo
Re: moonPhase Block Icons
Posted: Mon May 31, 2021 4:37 pm
I have already 'reordered' the look of the block and added the moon age indication
Posted: Fri Jun 04, 2021 4:52 pm
by psper
Hi!
Did you change the png files or the moonPhaseBlock.php file?
Thanks !
Paulo
Posted: Fri Jun 04, 2021 5:23 pm
The php script ( as I also reordered the phases )
Posted: Sun Jan 30, 2022 2:16 pm
by Meteofabro
For those wishing to try the Moonphase block with the real-time graphics of the Moon-Earth phases, you can download the block in ZIP format attached below.
Remember to save the original block on the server or on your PC if you want to restore.
Posted: Sun Jan 30, 2022 8:01 pm
Nice!
Posted: Mon Jan 31, 2022 3:14 pm
by Meteofabro
UPDATE to the moonPhase block.
The "Show the other side of the Earth on the Earth-Moon image" configuration has been added to the block.
This setting displays the opposite side of the Earth (Pacific zone) to the standard position (Atlantic zone).
Useful for Meteotemplate users to view the terminator (fictitious line on the Earth that delimits the illuminated part from the shaded part) on their Continent.
Posted: Mon Mar 07, 2022 4:57 pm
by tobydude
Meteofabro wrote: Sun Jan 30, 2022 2:16 pm For those wishing to try the Moonphase block with the real-time graphics of the Moon-Earth phases, you can download the block in ZIP format attached below.
Thanks. :)
Posted: Sun Nov 12, 2023 4:13 pm
ver 2.3
- updated earth/moon visualization ( to use fourmilab scripts )
- added few configuration option
ver 2.4
- removed stale css #footer definition ( which caused a footer text color change )
Posted: Sun Nov 12, 2023 6:15 pm
by Jolumarali
Thank you Davide, installation without problem, we missed you very much
José Luis :)
Posted: Mon Nov 13, 2023 6:40 am
by MeteoElMasnou
Thanks for the update Davidefa.
Greetings
Posted: Mon Nov 13, 2023 7:16 am
by djpoppy
Great update @Davidefa ;)
Posted: Mon Nov 13, 2023 7:20 am
by lemimi
In boredom... just ask and Davide does it!
Many thanks... Michel
Posted: Tue Nov 14, 2023 3:49 pm
by Meteofabro
Un aggiornamento fantastico, GOOD...
Posted: Tue Nov 14, 2023 4:18 pm
by tobydude
version":2.3b works fine here. Thanks.
Posted: Sun Nov 26, 2023 10:41 am
by Jolumarali
Hello Davide, Since the installation of moonPhase Block, the footer has some sharpness problems, test carried out uninstalling the Block. ditto on different browsers and on sites that have installed it.
Do you have any idea about this problem.
and thank you for your work
Posted: Sun Nov 26, 2023 1:27 pm
Yes, you are right, there was an an erroneous css definition that caused this.
Updating to v2.4 should fix it: viewtopic.php?t=2068#p12849
Posted: Sun Nov 26, 2023 1:47 pm
by Jolumarali
Thank you Davide, We can never thank you enough. :)
Posted: Sun Nov 26, 2023 8:09 pm
by MeteoElMasnou
davidefa wrote: Sun Nov 26, 2023 1:27 pm Yes, you are right, there was an an erroneous css definition that caused this.
Thanks Davide.
