moonPhase Block Icons
Hi all,
I use moonPhase Block but moon icons are correct only for South Hemisphere.
I think that for North hemisphere they are wrong.
It is diferente between north and south hemisphere.
Do you know how to correct this?
Thanks in advance,
Paulo
Thanks in advance,
Paulo
- MoonPhases.png (11.73 KiB) Viewed 55484 times
- WhatsApp Image 2021-05-31 at 16.07.31.jpeg (43.9 KiB) Viewed 55484 times
Re: moonPhase Block Icons
I have already 'reordered' the look of the block and added the moon age indication
- moonPhase_2.1a.zip
- (64.39 KiB) Downloaded 1183 times
Hi!
Did you change the png files or the moonPhaseBlock.php file?
Thanks !
Paulo
Thanks !
Paulo
- Meteofabro
- Software: Meteobridge RED PRO
For those wishing to try the Moonphase block with the real-time graphics of the Moon-Earth phases, you can download the block in ZIP format attached below.
Remember to save the original block on the server or on your PC if you want to restore.
- 2022-01-30 14_54_38-Moonphase.png (169.07 KiB) Viewed 55084 times
- moonPhase_2.1b.zip
- (65.04 KiB) Downloaded 1208 times
- Meteofabro
UPDATE to the moonPhase block.
The "Show the other side of the Earth on the Earth-Moon image" configuration has been added to the block.
This setting displays the opposite side of the Earth (Pacific zone) to the standard position (Atlantic zone).
Useful for Meteotemplate users to view the terminator (fictitious line on the Earth that delimits the illuminated part from the shaded part) on their Continent.
- 2022-01-31 16_12_28-MeteoFabro.png (316.07 KiB) Viewed 55066 times
- moonPhase_2.1c.zip
- (64.69 KiB) Downloaded 1498 times
- tobydude
- Station model: Netatmo
- Software: Weatherdiaplay
Thanks.Meteofabro wrote: ↑Sun Jan 30, 2022 2:16 pm For those wishing to try the Moonphase block with the real-time graphics of the Moon-Earth phases, you can download the block in ZIP format attached below.
ver 2.3
- updated earth/moon visualization ( to use fourmilab scripts )
- added few configuration option
ver 2.4
- removed stale css #footer definition ( which caused a footer text color change )
ver 2.4
- moonPhase_2.4.zip
- (65.95 KiB) Downloaded 1519 times
- moonPhase_2.3b.zip
- (65.96 KiB) Downloaded 1598 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Thank you Davide, installation without problem, we missed you very much
- MeteoElMasnou
- lemimi
In boredom... just ask and Davide does it!
Many thanks... Michel
- Meteofabro
- tobydude
version":2.3b works fine here. Thanks.
- Jolumarali
- Software: WlIP
Hello Davide, Since the installation of moonPhase Block, the footer has some sharpness problems, test carried out uninstalling the Block. ditto on different browsers and on sites that have installed it.
Do you have any idea about this problem.
and thank you for your work
- footer.jpg (6.03 KiB) Viewed 53409 times
Yes, you are right, there was an an erroneous css definition that caused this.
Updating to v2.4 should fix it: viewtopic.php?t=2068#p12849
- Jolumarali
- Software: WlIP
Thank you Davide, We can never thank you enough.
- MeteoElMasnou
Thanks Davide.davidefa wrote: ↑Sun Nov 26, 2023 1:27 pm Yes, you are right, there was an an erroneous css definition that caused this.
