Template unregistered
magical46
Post by magical46 » Fri Jun 18, 2021 10:44 am
Hi, recently all my pages,(plugins, admin etc) have at the top of the page
Template unregistered - Go to Meteotemplate Control Panel and Register Your Template :)
. I have seen it occasionally on some plugins but going to the plugin settings has fixed it, but now I can't find how to get rid of it. I have been using meteotemplate since it started and my site is registered. Help Please. Also when this is on a page there is no menu bar appearing as you will see here http://www.philsweather.co.uk/meteotemp ... /index.php for example. The homepage is working fine [http://www.philsweather.co.uk/meteotemp ... esktop.php][/url]
Phil
Re: Template unregistered
Post by davidefa » Tue Jun 29, 2021 8:40 pm
Hi Phil, I'm not able to reproduce your error.
The message should be displayed when the file admin/templateRegistered.txt is not present ( file that in your case is present )
The message should be shown on every page ( even the home page ) and in any case the menu bar should be present.
So the only thing I can say is there is "something wrong somewhere"
You can try with the header.php file attached, just unzip it in your template directory, before unzipping rename the existing header.php to header.orig ( it only prints a few variables, baseURL should correctly match the local path to your template directory )
One thing I noticed is your site is particularly slow ( don't know if my connection is slow ): did you ( recently ) change something on your server?
header.zip
(7.46 KiB) Downloaded 362 times
magical46
Post by magical46 » Fri Jul 02, 2021 9:07 pm
Thanks for the reply. The main change was that a few months ago my host company moved everything to their new servers, but even then it was all working ok, in fact a couple of pages that never worked before now work on the new severs, this has just started in the last week or two. Yes it is slow it always has been even on the old servers .
Phil
