Importing Data Issue
hankster
Station model: Weather Flow
Post by hankster » Sun Dec 10, 2017 2:50 pm
Just setting up the template and having an issue with importing data. I use Weather Display and used the function built-in to create the import file and upload to the web site. The uploaded files look good and all of the info is metric. Here are the results of loading the txt file (all of this looks correct):
The tested file has 8644 data sets.
Field delimiter is comma (,)
First dataset is: 2017/11/01 00:00,15.0,100.0,1019.2,1.9,1.9,0.0,0.0,45,0.0
The header row contains 10 columns.
The data row contains 10 fields.
Loaded data:
Field Field Number Value (first data set)
YYYY/m/d H:i 0 2017/11/01 00:00
avtemperature(C) 1 15.0
avhumidity 2 100.0
avbarometer(hpa) 3 1019.2
avwindspeed(km/h) 4 1.9
gustspeed(km/h) 5 1.9
rainfall(mm) 6 0.0
rainrate(mm/hr) 7 0.0
avdirection 8 45
avsolar 9 0.0
When I run a test of the files it shows that the info would be imported as English measure with no conversion from metric as shown below.
Summary
The following would be imported to database:
Date/time: 2017-11-01 00:00
Temperature: 15.0 F
Dewpoint: 15 F
Apparent Temperature: 16.2 F
Humidity: 100.0 %
Pressure: 1019.20 inhg
Wind speed: 1.9 mph
Wind gust: 1.9 mph
Precipitation: 0.00 in
Rain rate: 0.00 in/h
Wind direction: 45 degrees
Solar radiation: No solar sensor - ignored.
Ideas???
Re: Importing Data Issue
Post by Johnny » Sun Dec 10, 2017 8:50 pm
Hi Hankster, just a thought here, when you were setting up the template, did you set the correct units before your import?
Administration/Main Setup
hankster
Post by hankster » Sun Dec 10, 2017 9:18 pm
Hi Johnny, Been working with Jachym on this. I guess I just misunderstood the Summary output with the F, inhg, etc after the data. The units are all correct and everything imported correctly.
Post by Johnny » Sun Dec 10, 2017 9:25 pm
Oh Cool, that's good news, glad you're all sorted :)
i_fiorentino
Post by i_fiorentino » Fri Jan 12, 2018 11:52 pm
i'm very interested about import data from weather display.
Which file have you choice to import data?
Log files or whatelse?
Thank you so much.
Alessandro
Post by Jachym » Sat Jan 13, 2018 12:20 am
monthly log files (TXT)
hankster
Post by hankster » Sat Jan 13, 2018 1:58 am
In the logfiles directory you will see files named something like:
122017lg.txt
112017lg.txt
102017lg.txt
92017lg.txt
i_fiorentino
Post by i_fiorentino » Sat Jan 13, 2018 2:45 pm
Thanks for reply!
Two questions:
1) I've just finisched to complete import section but there isn't any field about rain rate in weather display logfiles.
how can i fill rain rate field on meteotemplate import data?
2) WD logfiles has monthly and yearly rain amount but these fields isn't show on meteotemplate import data.
How can i do to import also these data?
Here it is how meteotemplate read WD logfile....is it correct?
Loading file...
Loading CSV/text file from ../112010lg.txt
File loaded successfully.
Header row in the file, skipping first line, using for field labels.
Starting to parse data....
The tested file has 10250 data sets.
Field delimiter is space ()
First dataset is: 1 11 2010 0 2 07.3 94 06.4 1000.1 3 3 112 0.4 0.0 0.0 21.3 7.3
The header row contains 38 columns.
The data row contains 25 fields.
Number of columns is not equal to number of fields.
Loaded data:
day	0	1
month	1	null
year	2	11
hour	3	2010
minute	4	null
temperature	5	0
6	null
7	2
humidity	8	07.3
9	null
10	94
11	06.4
12	1000.1
dewpoint	13	null
14	null
15	3
barometer	16	null
17	null
18	3
19	112
windspeed	20	0.4
21	0.0
22	0.0
gustspeed	23	21.3
direction	24	7.3
Thank in advance for your support.
Alessandro
hankster
Post by hankster » Sat Jan 13, 2018 6:51 pm
You imported incorrectly. The option for "Date and Time Field" should be "Date and Time in a single field". Your field setup should then be as shown in the attachment.
i_fiorentino
Post by i_fiorentino » Sat Jan 13, 2018 8:10 pm
Is it ok this system answered?
Loading file...
The header row contains 1 columns.
The data row contains 1 fields.
Loaded data:
day month year hour minute temperature humidity dewpoint barometer windspeed gustspeed direction rainlastmin dailyrain monthlyrain yearlyrain heatindex	0	1 11 2010 0 2 07.3 94 06.4 1000.1 3 3 112 0.4 0.0 0.0 21.3 7.3
i_fiorentino
Post by i_fiorentino » Sat Jan 13, 2018 8:22 pm
Bingo!
This is the correct configuration:
....and system answer is:
Loading file...
Field delimiter is tab ()
The header row contains 17 columns.
The data row contains 17 fields.
Loaded data:
day	0	1
month	1	11
year	2	2010
hour	3	0
minute	4	2
temperature	5	07.3
humidity	6	94
dewpoint	7	06.4
barometer	8	1000.1
windspeed	9	3
gustspeed	10	3
direction	11	112
rainlastmin	12	0.4
dailyrain	13	0.0
monthlyrain	14	0.0
yearlyrain	15	21.3
heatindex	16	7.3
i_fiorentino
Post by i_fiorentino » Sun Jan 14, 2018 10:27 am
Morning to all.
I've completed setting form on import data menu.
All it seems ok but i've one question about that.
Rain rate value are not present as a field in weather display log.
Which number should i set in this field?
Thanks in advance,
Alessandro
