updated interactiveGraph block
Post by davidefa » Sat Apr 03, 2021 9:46 pm
Update the block to include additional sensors
ver 11.4c
- sensors grouped ( differently )
- added 2 axis graphs
- added option to rename multiple sensors
- added multiple sensors graphs: PP#, SM#, ST#, T#, H#, CO2_#
ver 11.4d
Added an option to handle 'events' ( leave blank if not used )
Currently supported ( may be expanded if needed ):
raining,MM ( shows precipitation when RR>0 in the last MM minutes, if MM=0 uses the data from meteotemplateLive.txt, if MM>0 uses data from database )
windy,SS,MM ( shows wind when wind speed > SS in the last MM minutes, if MM=0 uses the data from meteotemplateLive.txt , if MM>0 uses data from database, SS is expressed in the same unit as saved in database )
windyG,SS,MM ( shows wind when wind gusts > SS in the last MM minutes, if MM=0 uses the data from meteotemplateLive.txt, if MM>0 uses data from database, SS is expressed in the same unit as saved in database )
interactiveGraph_11.4d.zip
(10 KiB) Downloaded 1885 times
interactiveGraph_11.4c.zip
(9.54 KiB) Downloaded 1993 times
Semtex
Station model: Davis Vantage Pro Plus 2
Re: updated interactiveGraph block
Post by Semtex » Sat Apr 03, 2021 10:10 pm
Perfect !!
Grazie
meteolopik
Station model: Davis Pro 2 Plus
Post by meteolopik » Sun Apr 04, 2021 10:37 am
Super!! Thanks a lot :)
meteolopik
Post by meteolopik » Sun Apr 04, 2021 8:23 pm
T1 (extra temperature sensor 1) is not working for me, not sure if my settings are wrong. I named it T1 as in te database.
Post by davidefa » Sun Apr 04, 2021 10:58 pm
Corrected visualization of external temperature and humidity.
interactiveGraph_11.4a.zip
(9.52 KiB) Downloaded 1509 times
meteolopik
Post by meteolopik » Mon Apr 05, 2021 4:58 am
Fixed here! Thank you so much!
meteolopik
Post by meteolopik » Tue Apr 06, 2021 8:01 pm
Found another small bug. In extra temp the temperature does not go below 0 😊
Post by davidefa » Wed Apr 07, 2021 9:44 am
Removed 0° minimum for external temperature
interactiveGraph_11.4b.zip
(9.54 KiB) Downloaded 1838 times
meteolopik
Post by meteolopik » Wed Apr 07, 2021 1:57 pm
davidefa wrote: Wed Apr 07, 2021 9:44 am Removed 0° minimum for external temperature
Superb!! 😊
meteolopik
Post by meteolopik » Wed Apr 07, 2021 6:22 pm
- The dewpoint color in the temperature group stays white eventhough another color is set in the settings.
- Barometric pressure is not loading (pull from database incorrect maybe?
Post by davidefa » Wed Apr 07, 2021 8:11 pm
Corrected visualization of pressure sensor and color of dew point
(9.54 KiB) Downloaded 1491 times
meteolopik
Post by meteolopik » Thu Apr 08, 2021 2:16 pm
davidefa wrote: Wed Apr 07, 2021 8:11 pm Corrected visualization of pressure sensor and color of dew point
Great, works as a breeze! :D
Post by meteoesine » Sun Apr 11, 2021 7:28 am
ciao Davide, complimenti per il tuo skill, bravo!
ti propongo una ulteriore modifica, se fattibile:
in caso di precipitazioni in corso, si potrebbe far visualizzare il grafico della pioggia? poi, quando smette di piovere, ritornare al grafico con il parametro impostato di default
(praticamente una opzione che se piove visualizza il grafico precipitazioni, se non piove, quello di default)
grazie
Post by davidefa » Mon Apr 12, 2021 11:03 am
Added an option to deal with 'events'
Today should be the right day to test it
(10 KiB) Downloaded 1730 times
Post by meteoesine » Mon Apr 12, 2021 2:47 pm
GREAT !!!!
tnx
Post by davidefa » Wed May 19, 2021 10:26 pm
ver 11.4f
Minor update: added the capability to show only a subset of extra sensor.
For example if you want to show only extra sensor T3 and T4 set
Name of Extra Temperature sensors: 3=name3,4=name4
( settings are compatible with previous version )
ver 11.4g
Corrected a bug in wind bearing calculation ( no correction should be applied to bearing, but I applied the same correction of wind speed )
interactiveGraph_11.4g.zip
(10.07 KiB) Downloaded 1518 times
interactiveGraph_11.4f.zip
(10.24 KiB) Downloaded 1561 times
linux150
Station model: WMR968
Software: SDR -> Weewx -> MT
Post by linux150 » Fri Aug 13, 2021 4:15 am
Thanks for your update.
I´ve a problem with showing UV. UV is on true, but not shown,,,,
I DONT HAVE A SOLAR Sensor, so i didn´t aktivate in main settings.
Now i think, maybe UV is only shown WITH Solar Sensor is activated ?!
Any solution ?
PS: How can i make the bearing graph a little bit smaller?
EDIT: I tried and switched the "Solar Sensor" to true and now uv is shown! But i dont want this settings, because Solar shows allways empty entries in other blocks or actually data...
Maybe i try to edit the php file, will take a look ...
LG
Martin
linux150
Post by linux150 » Sat Aug 14, 2021 3:23 pm
So i answer myself, i did by try and error, because im an absolutly newbie in programming php (but i learned a lot, installing meteotemplate :D )
So i copied some parts and changed the parameters so now it works ONLY with UV Sensor and NO SOLAR SENSOR for my sensor conditions.
Maybe it helps somebody with same problem ....
LG
Martin
interactiveGraph_11.4h.zip
(10.91 KiB) Downloaded 1301 times
Post by davidefa » Thu Dec 23, 2021 10:16 pm
ver 11.4i
Minor update: added evapotranspiration
interactiveGraph_11.4i.zip
(10.95 KiB) Downloaded 1993 times
mchd17
Post by mchd17 » Sun Jan 16, 2022 10:50 pm
Another good block, thanks
Laglene
Station model: Davis pro 2
Software: Weatherlink
Post by Laglene » Mon Jan 17, 2022 2:59 pm
Hello Davide,
Thank you for this interactivegraph block, however a question please
How to change the color of the curves thank you
Didier
Laglene
Post by Laglene » Mon Jan 17, 2022 5:58 pm
Bonsoir Davide,
Désolé, la réponse est dans le nouveau block. je n'avais pas assez exploré votre travail.
Encore merci pour tout ce que vous faites.
Didier
Post by davidefa » Sun Feb 27, 2022 8:39 pm
ver 11.6
- minor update to remove some nasty side effects when customGraph block is installed too
( this update is only needed if you use block customGraph )
ver 11.7
- minor update: added option to show max solar radiation ( calculated ) along measured one
interactiveGraph_11.7a.zip
(11.17 KiB) Downloaded 1276 times
interactiveGraph_11.6.zip
(10.91 KiB) Downloaded 1468 times
Gerrit
Station model: Vantage pro 2 plus
Post by Gerrit » Tue Mar 22, 2022 2:47 pm
Good day to you,
what a nice adjustments these are, especially the possibility to show graphs of the soil sensors, that was the only thing that kept me with another software package, which I will stop right now.
I do have a small problem, which is also with the original file, that during the loading the program temporarily freezes.
Furthermore, I have the question if there are also adjustments possible to view the history of the ground sensors, I have data from 2018 onwards.
Gerrit
Post by davidefa » Tue Mar 22, 2022 4:18 pm
I'm currently working on extending The interactive and the extended graphs.
I've already updated the 'statistics' pages ( but currently didn't post the mod )
Please post a link to your site so I can take a look at the 'freezing issue'
