updated warningsEUregions
Preamble
Meteoalarm.eu is due to retire on 31 May 2021, but as of 2 June everything is still working, so there is no need to update now.
meteoalarm.org is already working and providing the necessary feed.
The only thing lacking in the new site is a graphical representation of the warnings on a country map.
Good news I made a script to display this country map... bad news it need a configuration file for every country ( not difficult but a little bit tedious ).
I made the configuration file for Italy and UK, so these are the only fully functional countries ( the others need to edit the file regions/xx.php, and for each region included, specify the coordinates of a point ( on the country map ) inside the region, and the coordinates where to display the warning icon, generally these points may be coincident )
Last version
ver 2.4 2024-12-05
- fix rss feed change
- fix finland regions definition
- fix 'sea boundaries'
http://realrunning.netsons.org/template ... ns_2.4.zip
Last version only for Norway, Sweden, Slovenia
ver 2.5 2024-12-26
- changed feed from rss to json
- use leaflet to show polygons on map
- added tooltip with warning description
- approximate coordinates:
Norway 64.91, 16.91, zoom 4.4
Sweden 64.08, 16.44, zoom 4.5
Slovenia 46.16, 14.92, zoom 7.8
http://realrunning.netsons.org/template ... lygons.zip
Last version
ver 2.4 2024-12-05
ver 2.5 2024-12-26
- warningsEUregions_2.2d.zip
- (961.15 KiB) Downloaded 1684 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Re: updated warningsEUregions
Hello Davide
To edit the regions / xx.php file, and for each region included, I have to specify the coordinates of a point (on the country map) inside the region, and the coordinates where to display the icon of warning,, can I find them where coordinates of a point?
France has 95 departments.
Thanks for getting on the track.
I generally use gimp for this ( another image editing software is ok )
The icon upper left coordinates is generally enough ( if it is inside the region itself ).
Yes is going to be a little tedious repeating the process 100 times ; - )
- Jolumarali
- Software: WlIP
Hello Davide
I did a test with the regions on alert in France, and here is the result.
duplicates on alerts and map that is not displayed.
I emptied the cache and identical.
I probably made a mistake?
example of modification
"FR028"=>array("name"=>"Var", "x"=>array(486), "y"=>array(461), "xi"=>486, "yi"=>461),
- Jolumarali
- Software: WlIP
Ok Davide
I would do this on time, 95 departments is a long time and for the meteo alarm monment is working.
what is weird is that the map of italy is displayed without the alerts, I tried it. and at this moment I find the link of the map of France.
I have corrected the duplicated warnings.
Added an option to show only the active warnings ( and to deactivate caching, for debug )
If the map does not show it means there is an error/warning in the map.php script.
In this case please upload the fr.php script ( and the cache directory ) so I can replicate it.
I have separated the countries directory in a different file
- warningsEUregions_2.2h.zip
- (963.55 KiB) Downloaded 1180 times
- warningsEUregions_countries_2.2h.zip
- (32.08 KiB) Downloaded 1177 times
- Jolumarali
- Software: WlIP
Bonsoir Davide
Perfect, I just have to enter all the coordinates, these are the icons that are more difficult to place, small offset
attached an example, now at work.
the error of the map I found an omission of parenthesis in the coordinates
"FR090"=>array("name"=>"Corse du Sud", "x"=>array(54), "y"=>array(482), "xi"=>50, "yi"=>488),
When I'm done, I'll send you the fr.php file
But don't be in a hurry
with google translator
- Jolumarali
- Software: WlIP
Hello Davide
Herewith full fr.php
Now wait for alerts, to detect errors, especially icon location.
the 27 alerts of the day, everything is OK
Have a good day and thanks again
- fr.7z
- (1.81 KiB) Downloaded 1238 times
Thank you José Luis.
I have attached the mapall.php script which shows all regions/departments on a single page, it can be used to check for imperfections.
- mapall_01.zip
- (1.45 KiB) Downloaded 1372 times
- Jolumarali
- Software: WlIP
Hello Davide
I find myself with the countries in text: Black, I was able to modify the background, but do not see how to put the text in white.
can you help me?
can you help me?
Added an option to define region name text color
Colors can be conventional color names ( white, yellow... ) or rgb values ( format: #rrggbb )
- warningsEUregions_2.2i.zip
- (970.4 KiB) Downloaded 1228 times
- Jolumarali
- Software: WlIP
Hello Davide
countries .fr.php full update done.
I still have a small request, could we classify the countries in alphabetical order, like in the original Jachym block,
- fr.a.7z
- (1.81 KiB) Downloaded 1363 times
Sorted region names in alphabetical order
- warningsEUregions_countries_2.2l.zip
- (51.58 KiB) Downloaded 1435 times
- warningsEUregions_2.2l.zip
- (974.8 KiB) Downloaded 1247 times
- Jolumarali
- Software: WlIP
Ciao David
Perfetto e grazie ancora per il tuo lavoro.
amicizie
amicizie
- Jolumarali
- Software: WlIP
Hello Davide
the development of the Block is perfect and complete, BUT there are some inconsistencies and delays with the official alert updates ...
at least for France.
correct
inconsistently
So I come back for the moment to the Jachym Block which still works (see meteoAlarm for the update in the future of these URLs).
You will look for Italy, this morning 4 coutries in alerts and on your Block (No warnings)
friendships
correct
inconsistently
friendships
I have seen these differences between the old and the new site.
But ( apart from errors I may have introduced ) these are mainly due to differences in the xml feeds that the two sites report.
I think the new meteoalarm.org has a few 'hiccups' ( imperfections )
For example in this moment the italian region Valle d'Aosta shows two overlapping warnings ( that should be merged in a single extended warning )
Similar is the case of the neighbouring province Haute Savoie report two overlapping warning ( the first is a 2 minute warning today from 18:51 to 18:52 )
I think there is still something to be 'fine tuned' on meteoalarm.org
Regarding Italy, for more than a week meteoalarm.org stopped reporting italian warnings.
I sent an email to meteoalarm@zamg.ac.at reporting this. Got a reply that they where investigating... now warnings are available again
I like this weathe software. Thanks! With the increasing popularity of mobile devices and their increasing functionality, there is an increased need for app development software and services https://mlsdev.com/services/business-analysis. Businesses and organizations around the world are looking for ways to improve their business practices and increase their profitability by developing apps that target specific audiences and help convert web visitors into paying customers. In addition, it enables organizations to measure performance across the organization and reduce the time spent implementing the required policies. Custom app development software development platforms support these activities by providing app development services, application programming interfaces (APIs) and mobile device management.
- Jolumarali
- Software: WlIP
Ciao Davide
Hai un'idea dell'errore che si verifica da questa settimana sugli avvisi UE nella tua versione, Nessun avviso sulla Francia, è quello della Svezia che viene visualizzato.
ho svuotato la cache
Grazie Davide
Grazie Davide
There is something ( wrong ) going on with meteoalarm.org rss feed.
The French feed contains data relative to Finland ( the items geocode is always Finnish: <link>https://meteoalarm.org?geocode=EMMA_ID:FI001</link> )
I have sent an email ( to meteoalarm at zamg.ac.at ) signalling the problem.
- Jolumarali
- Software: WlIP
Tornando alla normalità, grazie, Davide
I found and issue.
in Slovenia we have red weather alert in southeast region right now. But on my page are all region green.
Any suggestion what to do?
Andrej
Andrej
Did the block function correctly in the past?
I'm asking because I noticed the format of the warning issued by meteoalarm.org for slovenia does not correspond to the standard.
Maybe this is a temporary issue that will resolve in the next days.
If not I can notify the meteoalarm support contact.
In any case I made a quick fix ( to derive a code, that is missing in the alerts, from the region name, but this could fail in the future if region names are changed )
ver 2.3
http://realrunning.netsons.org/template ... ns_2.3.zip
- added quick fix for slovenia warnings missing geocode
ver 2.3
- meteolopik
Hmm, I’m not a coder like some guys here but it occurred to me that the link to the actual feed is not the same as the current feed meteoalarm uses. They refer to https://feeds.meteoalarm.org/feeds/mete ... rss-europe while the file warningsEUregionsBlock.php points to a different one. Might that be an issue or am I just being a code n00b?
Meteoalarm.org has several rss feeds: https://feeds.meteoalarm.org ( whit only limited informations )
The one you refer to is a general european feed.
The block uses the nation specific feed ( which contain more information ), this is the Netherlands one: https://feeds.meteoalarm.org/feeds/mete ... etherlands
