Gaugus are not correct
pd3lkn
Station model: ws4000
Software: cumulus
Post by pd3lkn » Sun Dec 12, 2021 9:28 pm
hi all i'm upgradet from cumulus to weather display but the wind speed an rain gauges are not responding in the template
when i look at the wather display screen its reeds te correct speedin KMh and rain into mm but into the template gauges its stays at 0.0
can anny one help me to solve this please ?
see my meteotemplate at : www.pd3lkn.nl
greetings Eric
Re: Gaugus are not correct
Post by davidefa » Sun Dec 12, 2021 10:14 pm
Check the main setup, adjustments section, the 'Daily precipitation' and 'Wind speed' parameters should be 1 ( or something like that ) but not 0, as these are multiplicative parameters.
I noticed that your graphics are a little bit weird ( for example the temperature one has a lot of 'square wave' noise superimposed )
pd3lkn
Software: cumulus
Post by pd3lkn » Mon Dec 13, 2021 10:13 am
Thanks that was the trick
now the only thing i have to figure out is the wind gauge compass is giving the wrong direction when it is South its pointing to the SW so its a view degrees off
