ver 1.0
Simple block to show aurora borealis past data and forecast ( sorce https://www.swpc.noaa.gov )
Only 2 options
- n. days of past data ( to show ) along with available forecast
- show graph/map when collapsed
Image shows block expanded
ver 1.1
- added option to select north/south hemisphere chart
- added option to select local/UTC time ( previous version was UTC only )
Comments are welcome ( as always )
new aurora ( borealis ) block
- aurora_1.1.zip
- (4.73 KiB) Downloaded 789 times
- aurora_1.0.zip
- (4.41 KiB) Downloaded 820 times
Re: new aurora ( borealis ) block
ver 1.2a
- removed Kp at 1 min interval graph ( not available any more )
ver 1.3
- forecast image substituted by past 24h animation ( thanks to hanis scripts ). It takes a while to load all the images
ver 1.3
- aurora_1.3.zip
- (40.26 KiB) Downloaded 1275 times
- aurora_1.2a.zip
- (4.68 KiB) Downloaded 765 times
- MeteoElMasnou
Thank you Davide.
Working
