updated radarEU block ( radarSat24 )
Post by davidefa » Thu Feb 10, 2022 2:25 pm
ver 3.2
- added options to configure the 2 maps ( left and right map ), single map is supported too
- added option do define initial map type and timezone
NOTE
I think that this block should be called radarSat24 as it shows maps for Europe And Africa ( currently America, Asia and Oceania not working )
Wondering if may be useful to add a second drop down box to select map type independently for left/right map
radarEU_3.2.zip
(2.6 KiB) Downloaded 1104 times
Jolumarali
Station model: Vantage Vue
Software: WlIP
Re: updated radarEU block ( radarSat24 )
Post by Jolumarali » Thu Feb 10, 2022 6:49 pm
update completed
thank you davide
djpoppy
Station model: GW2000 - WS90
Post by djpoppy » Fri Dec 22, 2023 7:55 am
Does it still work for you? My radar doesn't load anymore...
Post by davidefa » Fri Dec 22, 2023 11:28 pm
Yes, sat24 has changed, so need to update the block
Post by davidefa » Sat Dec 23, 2023 6:01 pm
Quick and dirty block update:
ver 3.3
- changes due to sat24.com changes
- available only rain radar and satellite maps
- maps are now provided by meteox.com and cover the whole world ( so radarEU is not that appropriate any more )
- rerun the setup as parameters are completely different
- you can still setup one or two maps
To center a map 'on a country', fill in the first parameter ( which is the 2 chars ( always lower case ) code of the country, for example: it for Italy )
To center a map 'on a location', fill in the second parameter ( see https://widgets.meteox.com/en-GB )
Only include one of these two parameters ( if you include both only the 'country code' will be considered ).
Here is the block ( max 3 attachments per post )
ver 3.4 ( Dec 30, 2023 )
- bug fix ( location on regional/right map )
- corrected dropdown menu position
- added 'default setup' for new installations
radarEU_3.4.zip
(3.25 KiB) Downloaded 1065 times
radarEU_3.3.zip
(2.95 KiB) Downloaded 1219 times
djpoppy
Post by djpoppy » Wed Dec 27, 2023 5:09 pm
Thanks @davidefa ;)
giando11
Station model: Davis pro 2
Software: Weatherlink
Post by giando11 » Sat Dec 30, 2023 7:30 am
Hi davide, on my site the location doesn't work. Zoom only on Rome. The code that i setting are correct but zoom only to rome
Post by davidefa » Sat Dec 30, 2023 3:13 pm
The updated version, on my previous post, should fix the issue you noted
Weerstation Bolsward
Post by Weerstation Bolsward » Mon Jan 15, 2024 8:57 pm
thank you
Weerstationwoerden
Post by Weerstationwoerden » Thu Jan 18, 2024 8:56 pm
Thanks it's works fine
