updated extraT block, new allSensors block
Post by davidefa » Mon May 10, 2021 8:07 pm
Updated the extraT block:
- it can show data from any temperature sensor ( T, D, A, TIN, T1-T8, TS1-TS8, LT1-LT8... )
( need to specify the 'full name' of the sensor )
Added also a block ( allSensors ) to show the value from any sensor ( not only temperature sensor )
extraT_2.1.zip
(1.67 KiB) Downloaded 571 times
allSensors_2.1.zip
(2.13 KiB) Downloaded 1061 times
meteolopik
Re: updated extraT block, new allSensors block
Post by meteolopik » Wed May 12, 2021 12:01 pm
Thanks a lot! :)
xBenny
Station model: GW1000
Software: ecowitt plugin
Post by xBenny » Wed Jun 15, 2022 2:40 pm
Hi, I have a problem with the encoding of the allsensors block. I tried to change the encoding of individual files to both CP1250 and UTF8 no BOM, but the problem is still the same. Any advice? Thanks
Right title is "Externí čidla"
https://www.pocasi-klabava.cz
Post by davidefa » Wed Jun 15, 2022 3:21 pm
You can use something like this ( in block settings ):
Externí čidla
i.e. substitute the unicode chars with:
&#xHHHH;
or
&#DDDD;
where HHHH is the hexadecimal representation of the unicode char
and DDDD is the decimal representation of the unicode char
xBenny
Post by xBenny » Wed Jun 15, 2022 3:54 pm
Tricky but it works. Interestingly, I tried this before directly into a settings file and it didn't work. But through the block settings it works. Thanks :)
davidefa wrote: Wed Jun 15, 2022 3:21 pm You can use something like this ( in block settings ):
Externí čidla
&#xHHHH;
or
&#DDDD;
