I noticed quite a few months ago, that the Forecast is no longer working from the summary block. All other 'tabs' - Today, Current Conditions etc seem to work.
Does anybody know the cause/if there is a fix?
Thanks!
Forecast missing from 'summary' block
Re: Forecast missing from 'summary' block
Version 5.6 should be ok: viewtopic.php?f=54&t=2278&p=11473&hilit ... ock#p11431
Thanks David,
I have deleted the old summary block, and uploaded the new block - but still no forecast.
I have also cleared my cache, tried different browsers, as well as clearing the cache from the Blocks Setup page.
No luck with any of these attempts.
Anything else I should try?
Sorry forgot to mention that you have to rerun the block setup ( as location format changed in yr.no api v2.0 )
Okay - All done.
One last thing - this is not important, just an observation.
When looking at the forecast, all the day names start in lower case e.g monday, tuesday... when the 'proper' English says that they should be capitalised - Monday, Tuesday etc.
Is there any way to fix this - every time I look at the forecast and see the lower case it annoys me, and I wish I could fix it!!
Thanks!
Thanks!
This update should fix it: viewtopic.php?f=54&t=2278&p=11431#p11431
