need help for ecowitt wh57 lightning device
Re: need help for ecowitt wh57 lightning device
Your gw1100 has been reset and so last distance and last time are unavailable ( but initialized with 0 that as a timestamp is 01/01/1970 ).
Did not consider this case but it could be shown 'unavailable' or '--'
- Station model: Ecowitt WS90
Hello David!!!
I have been away from MT for a good while and catching up before php 7.4 expires.
As Dehatter says "You are definitely THE MAN - THE LEGEND!!"
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
Ciao,
Would it be possible to move the total lightning year under Strikes last 60min and above last strike?
but only total lightning, however
the other comments $tunder_txt (Storm is approaching at, Storm is going away, ...) leave them under where they are
thanks in advance
thanks in advance
- ScreenShot01135.jpg (34.09 KiB) Viewed 38601 times
Hi!
I seem to have a problem in ver 2.3 where the 5 min section is not updating and the approaching storm at the bottom is not working. It was with a previous version which I don't remember the number of but assuming ver 1.0
I am still only using PHP 7.4 because am afraid to make the leap to 8.0 or 8.1. Could that be my problem and which should I try. PHP ver num (8.0 or 8.1) I mean.
Edit: I tried updating to both php 8.0 and 8.1 but my site comes up with a blank page and having to revert back to php 7.4 I think (I forgot the version number)
I mentioned this in other posts encase you run across them.
- Lightning-block
- Screenshot 2022-08-29 173823.png (90.39 KiB) Viewed 38596 times
Julius
- Software: meteobridge
Andy, may I ask how you got the WH57 lightning data correctly into meteotemplate?
I see these in my meteobridge: near the bottom are the lightning ones. I added
to the api call to MT, but for some reason this does not yield anything more than just that L value.
&L=[lgt0!0total-dmax.0:]&LD=[lgt0!0dist-lastval.0:]<=[lgt0!0total-nonzerotime=epoch:]-
leonrossouw
I need some help with lightningew block please.
My data shows in meteotemplate database…see attachments…but the block always shows only 1 strike…latest.
I have seet cache time to 0
Thank you,
Leon Rossouw.
Thank you,
Leon Rossouw.
- IMG_0382.png (402.56 KiB) Viewed 37930 times
leonrossouw
Screenshot of block
leonrossouw
Screenshot
- IMG_0383.jpeg (308.06 KiB) Viewed 37929 times
leonrossouw
Screenshot database
leonrossouw
Screenshot database
- meteoesine
try to set your block like this
- Screenshot - 10_01_2024 , 10_18_57.jpg (49.67 KiB) Viewed 37917 times
leonrossouw
Thank you…did that but still showing only current strike
leonrossouw
I eventually got it sorted thank you,
Problem was with my database..
Leon
Leon
