RESOLVED Weird addition to URL
kd7eir
- Station model: Ecowitt Wittboy
- Software: FOSHKplugin
My URL is https://www.kc5jim.org/indexDesktop.php
But when I go there, this is added to the end of the URL: #https://api.met.no/weatherapi/locationf ... =-110.7849
This happens is all browsers. I've flushed DNS, cleared cache, incognito, different computer, and it's still the same.
Any idea what appending that to my URL?
FSC830
Re: Weird addition to URL
Is there any redirection activated?
I cant even open the URL kc5jim.org "not found", is that a new web site?
Found your (?) pages at findu.com, but the URL above cant be accessed/found.
73
Edit: Seems that the addendum to the URL is the data your weather station is sending. This URL can be accessed.
73
kd7eir
No re-direction. I made a change to my DNS, so it will be awhile for it to come back up. Sorry for that.
FSC830
You made a change to your DNS!??
This should not affect access to the URL.
Or did you request removing the DNS entry for this URL from provider?
kd7eir
The DNS change was totally outside of the URL issue - I just picked a bad time to make a UPS update
FSC830
Really strange, nslookup does not resolve kc5jim.org, very unusual.
FSC830
Yes, I see. Strange, do you have any relation to the site "https://api.met.no"?
Never seen that such an URL is added to the Meteotemplate URL.
FSC830
Just noticed, that the geo-coordinates at your meteogram block are matching the ones in the "tailgating" URL!?
kd7eir
WOW! Thank you! I deleted the meteogram block and the extra URL is gone. Those coordinates were mine, but no idea why they were dispalying.
FSC830
Which version of Meteogram was it? I have 3.3d1 (no idea if this is sometimes called 3.4), its more or less 3.3 with colors.
But it does not add an URL to the indexDesktop.php.
I used also v4 for a very short time, but because it was not working properly I switched back to the 3.x version.
Edit: BTW, did you notice that are two blocks not displayed at your page? At middle left a block is not found, at the right is a request for creating the settings first.
FSC830
Re: RESOLVED Weird addition to URL
Ok, then we know the culprit.
Did you notice my edit in the last post?
FSC830
Sorry to say, not at all.
At middle right, between indoor conditions and sun eclipse is a block which requires setup before use.
I see, you are using meteogram v4 again, URL is added again.
kd7eir
I think you might be seeing a cached version of the page, it's fine on my side.
FSC830
There is still a block "Please go to your admin section..."
