Sea Temperature Block Trouble
LOBWX
Station model: Ambient WS 1401-IP
Software: MeteoBridge
Post by LOBWX » Tue Nov 13, 2018 2:30 am
Having a bit of an issue with the seaTemperature block on https://lobwx.com its in the block named "Marine Specs" on the right, under the hamburger.
Im am trying to grab this data north-america/united-states/morro-bay.htm from https://www.seatemperature.org
Here is the output I am getting:
Notice: Undefined offset: 1 in /home/foe33895/public_html/lobwx/template/homepage/blocks/seaTemperature/seaTemperatureBlock.php on line 82
Notice: Undefined offset: 2 in /home/foe33895/public_html/lobwx/template/homepage/blocks/seaTemperature/seaTemperatureBlock.php on line 83
Notice: Undefined offset: 3 in /home/foe33895/public_html/lobwx/template/homepage/blocks/seaTemperature/seaTemperatureBlock.php on line 84
Notice: A non well formed numeric value encountered in /home/foe33895/public_html/lobwx/template/scripts/functions.php on line 165
Warning: A non-numeric value encountered in /home/foe33895/public_html/lobwx/template/scripts/functions.php on line 165
LOBWX
Re: Sea Temperature Block Trouble
Post by LOBWX » Fri Nov 16, 2018 12:28 am
Weird started working again ???
Julius
Software: meteobridge
Post by Julius » Sun Dec 25, 2022 2:40 pm
This block is broken now. I only see 0C values everywhere people use it..
tobydude
Software: Weatherdiaplay
Post by tobydude » Sun Feb 19, 2023 11:03 am
Can it be fixed?
Post by alexvanuxem » Sun Feb 19, 2023 4:59 pm
it's fixed
follow this thread viewtopic.php?f=56&t=2347&p=12117&hilit ... ure#p12117
hope it helps?
grtz
Alex
tobydude
Post by tobydude » Sun Feb 19, 2023 5:15 pm
alexvanuxem yes !
I think it works on my weaterpage now.
Thanks.
Juan Maria Vilaró
Software: Weather Dislplay
Post by Juan Maria Vilaró » Fri Mar 10, 2023 9:24 am
Good morning, I ask for help to repair the block "seaTemperature version 2.2" has been working correctly for a long time, but for a while it only indicates 0.0 and I don't know how to fix it, could someone help me or give me some solution?
thank you so much
URL: https://badameteo.com/template/indexDesktop.php
Post by alexvanuxem » Fri Mar 10, 2023 1:55 pm
when I visit your site, it seems to be working: I see 12.7°C in Badalona?
Grtz
FSC830
Post by FSC830 » Fri Mar 10, 2023 4:24 pm
@alexvanuxem: my guess, you are looking at the wrong page. ;)
When language is set to English: Weather -> Seatemperature
@Juan
Check, if the quick and dirty solution runs for you.
Backup the original files in advance.
From archive copy functions.php to </template_root/>scripts and the seaTemperature.php to the referring block directory.
Please give a feedback ;)
Saludos
!!! Note: file for seaTemp block!
seaTemp.zip
(11.1 KiB) Downloaded 1290 times
Edit: Anyhow, just noticed, that your block looks different than mine!?
Where did you download this block? Is yours really a "block" or a "plugin"?
Edit II: just found, you are using a PLUGIN, not a BLOCK. Please do not mix up these two.
Now looking in the plugin... done :D
Ok, please download the index.zip, put the extracted index.php in seaTemp plugin directory and test.
!!! Note: file for seaTemp plugin!
index.zip
(2.63 KiB) Downloaded 1245 times
Post by alexvanuxem » Sun Mar 12, 2023 5:59 pm
i got confused , when its's a block its visible at the homepage,
when its a plugin it's visible at weather etc???
so it's not block but a plugin?
8-)
FSC830
Post by FSC830 » Sun Mar 12, 2023 6:25 pm
No, there are two different modules.
One is a block, showing 5 targets maximum, the other is a plugin with only one target and statistics.
Me too was confused, as the "seatemp block" was mentioned.
Looking at Juans website shows a difference to my installed block.
Then I noticed, that there is a plugin too for sea temperature.
And yes, the blocks can be added to desktop, whereas plugins are visible from the menu bar.
Confusing, if different modules for same/similiar data are available.
Cavaliere
Station model: Peet Bros Ultimeter 2100
Post by Cavaliere » Sun Nov 19, 2023 8:32 pm
I just tested the file of the block in question, indicated above and now the block loads it, but the current data brings me 0.0 °C. And also if I change city, it doesn't change in the block.
Do you have a solution?
FSC830
Post by FSC830 » Tue Nov 21, 2023 12:14 pm
What is your site (link)?
Block or plugin?
Cavaliere
Post by Cavaliere » Tue Nov 21, 2023 5:07 pm
FSC830 wrote: Tue Nov 21, 2023 12:14 pm What is your site (link)?
Block or plugin?
Block Seatemperature.
My site: www.ombarcellonapg.com
Regione seatemperature this: https://www.seatemperature.org/europe/italy/milazzo.htm
Cavaliere
Post by Cavaliere » Fri Aug 01, 2025 9:28 pm
Hi everyone, has a solution been found for this sea temperature freeze?
FSC830
Post by FSC830 » Sun Aug 03, 2025 4:00 pm
Sorry, did not see your answer in Nov. 2024... :oops:
The block runs at my test site without any issues.
I am running at PHP 8.3, what is your version?
And which are the locations you choose for the sea temperature?
P.S. Just checked, entering Milazzo at my site works too, actual temp was 26.8°C (Sunday, August 3rd, 2025, 18:10 CEST)
