Downloads not working (resolved)
RobRead
Post by RobRead » Sun May 21, 2023 5:44 pm
I was having issues with ssguages so I decided to download normal gauges but when I click on donwload,
I get
Warning: Undefined array key "key" in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 15
Warning: Cannot modify header information - headers already sent by (output started at /data/web/virtuals/104571/virtual/www/web/downloadRequest.php:15) in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 250
Warning: Uninitialized string offset 0 in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2045
Warning: Uninitialized string offset 7 in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2045
Warning: Uninitialized string offset 1 in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2046
Warning: Uninitialized string offset 2 in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2046
Warning: Uninitialized string offset 3 in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2047
Warning: Uninitialized string offset 4 in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2047
Warning: Uninitialized string offset 8 in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2048
Warning: Undefined array key "HTTP_CLIENT_IP" in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2052
Warning: Undefined array key "HTTP_X_FORWARDED_FOR" in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2052
Warning: Undefined variable $iptolocation in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2066
Fatal error: Uncaught ValueError: Path cannot be empty in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php:2066 Stack trace: #0 /data/web/virtuals/104571/virtual/www/web/downloadRequest.php(2066): file_get_contents('') #1 {main} thrown in /data/web/virtuals/104571/virtual/www/web/downloadRequest.php on line 2066
this happens on any attempt to download.
milesb
Re: Downloads not working
Post by milesb » Sun May 21, 2023 6:58 pm
Confirm I get the same error.
Hopefully it is a sign that Jachym is working on updates for PHP 8.x
johnathan
Station model: wh1080
Post by johnathan » Mon May 22, 2023 10:00 am
Try again and again and again!
beaumariswx
Station model: Davis Pro 2 Plus
Software: CumulusMX
Post by beaumariswx » Tue May 23, 2023 9:45 pm
Same Here.
FSC830
Post by FSC830 » Mon May 29, 2023 6:54 pm
Just downloaded gauges (v7.1) and ssgauges (v3.1) without any issues. May be fixed in the meantime?
RobRead
Post by RobRead » Sat Jun 03, 2023 9:54 am
Thanks, FSC830
Yes, it is working fine now.
