After the update I noticed that the above plugin doesn't work anymore on PHP 8 and 8.2. If I use PHP 7.3 it works. The same problem is present in the demo page of Meteotemplate. The most serious thing, however, is that the database is not updated. How to solve it? I'm currently using PHP 7.3 and everything is working fine.
SteelSeriesPlugin not working under Cranberry (PHP 8 and 8.2)
mrerik
- Station model: Davis Vantage pro 2
- Software: Weatherlink
- Schermata 2023-08-31 alle 05.54.24.png (362.37 KiB) Viewed 7295 times
cw3beck
Re: SteelSeriesPlugin not working under Cranberry (PHP 8 and 8.2)
I noticed something similar when I was behind a VPN. When I'm not - the steel series gauges work fine (both on the blocks and as a plugin.
https://eaglerisingwx.synology.me/indexDesktop.php
