Custom Pages
kd7eir
- Station model: Ecowitt Wittboy
- Software: FOSHKplugin
Custom Pages
I am trying to create either a custom page or menu item that opens https://www.astrospheric.com/?Latitude= ... c=Forecast
I tried a custom page - I can get a list to display a link, but I would like the menu item or the custom page to automatically show the website. I have an embed for it, but java script is not allowed, so I can't use it.
Any suggestions?
Any suggestions?
FSC830
Re: Custom Pages
Actually I am not sure if I caught the issue correct.
As an example: if you go to my page and click Weather - Metar Decoder, a new tab is opened.
Is that, what you want to achieve?
- lemimi
Re: Custom Pages
Or perhaps this:
https://lemimi.fr/template/custom/custo ... cod%C3%A9s
If it is this, open your control panel,
Click “Create new custom page”.
Then "New page". In the frame that appears, I enter the following code:
<!DOCTYPE html>
<html>
<head>
<h1>Metar Taf décodés</h1>
</head>
<body>
<center><object type="text/html" data="https://www.metar.lemimi.fr/wx7.php" width="98%" height="800">
</object>
</center>
</body>
</html>
You just have to replace the URL...
Or perhaps this:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
</object>
</center>
</body>
</html>
kd7eir
Re: Custom Pages
That worked perfectly. Thank you.lemimi wrote: ↑Fri Oct 20, 2023 12:20 pm Hello,
Or perhaps this:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
</object>
</center>
</body>
</html>
- amonphi
- Station model: Ecowitt GW1003
- Software: WU
Re: Custom Pages
Hi @lemimi ,lemimi wrote: ↑Fri Oct 20, 2023 12:20 pm Hello,
Or perhaps this:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
</object>
</center>
</body>
</html>
I'm trying to create the same custom page with the same procedure indicated here but I only get the Namespace of the page I created, the URL I'm interested in viewing is this https://aviationweather.gov/data/metar/ ... ecoded=yes while the html code I inserted is this:
<!DOCTYPE html>
<html>
<head>
<h1>Metar Taf decodificato</h1>
</head>
<body>
<center><object type="text/html" data="https://aviationweather.gov/data/metar/ ... ecoded=yes" width="98%" height="800">
</object>
</center>
</body>
</html>
Can you kindly point out to me where I'm going wrong?
Re: Custom Pages
you can also link that page to a new tab in your menu.
login as admin, in administration page, click on menu,
add a new tab, save, update menu
on the line of the new tab, enter your url and it should work
alex
alex
- amonphi
- Software: WU
Re: Custom Pages
Hi,alexvanuxem wrote: ↑Thu Nov 16, 2023 1:58 pm you can also link that page to a new tab in your menu.
alex
yes yes that is an alternative which, in the end, is also simpler to obtain but, I was interested in understanding the Custom Pages providing HTML code.
Thanks anyway for the suggestion, surely if I can't get the Custom Pages I will adopt that system!
- lemimi
Re: Custom Pages
Many sites prohibit their website from opening in an iframe.
Thus, to block the display of a page in a frame or iframe, the HTTP header option (HTTP Header) X-Frame-Options is used.
Four values are possible for X-Frame-Options:
DENY: The page cannot be displayed in a frame, no matter which site tries to load it.
SAMEORIGIN: The page can only be displayed by a site of the same origin.
ALLOW-FROM uri: The page can only be displayed in a frame from the specified origin.
ALLOWALL: The page can be displayed in a frame by all sites. (by default)
Alexvanuxem's solution will open the site in a new tab...
Good evening... Michel
kd7eir
Re: Custom Pages
I had the same issue - the page I wanted to link prohibits opening in an iframe. I had to make the URL a menu entry under my Astronomy menu. The link then opens in a new tab.
#default(moonPhase)
#default(astroCalendar)
#default(sunTimes)
#plugin(sunMoon)
#default(solsticeEquinox)
#default(dayNight)
#plugin(eclipses)
#plugin(solarSystem)
#plugin(spaceWeather)
#plugin(nightSky)
Astrospheric Seeing Forecast | https://www.astrospheric.com/?Latitude= ... c=Forecast | mticon-logo | blank
#default(moonPhase)
#default(sunTimes)
#plugin(sunMoon)
#default(dayNight)
#plugin(eclipses)
#plugin(nightSky)
amonphi wrote: ↑Thu Nov 16, 2023 1:50 pmHi @lemimi ,lemimi wrote: ↑Fri Oct 20, 2023 12:20 pm Hello,
Or perhaps this:
<!DOCTYPE html>
<html>
<head>
</head>
<body>
</object>
</center>
</body>
</html>
<!DOCTYPE html>
<html>
<head>
</head>
<body>
</object>
</center>
</body>
</html>
- amonphi
- Software: WU
Re: Custom Pages
Hi,lemimi wrote: ↑Thu Nov 16, 2023 7:16 pm Hello,
thanks for the explanation, unfortunately not knowing the various programming codes and the related problems, often caused by external sources, I thought it was just my problem, but no.
I will follow the alternative solution indicated then.
Thanks again for the confirmation
Pierluigi
- amonphi
- Software: WU
Re: Custom Pages
i understood that the custom page with the indicated code worked for you.
No problem anyway, I use a link via the menu.
Pierluigi
