Hi All,
on the install I get a install fail on the following error message- "Please check your climateID, it must be a valid number."
I followed the instructions to get to http://www.meteotemplate.com/template/p ... te/map.php and zoomed into get my exact location but on Edge and Opera no popup appears with a location!
Marcus- MM0ZIF
Install error
MM0ZIF
- Station model: Ecowitt 1xxx
Install error
MM0ZIF
Re: Install error
To determine the code for your location, go to this page and here you will see a map. Zoom-in and find the point that best represents your location. Then click on it and in the popup dialog click Select. You will be redirected to the climate page of that particular location. Now look at the URL and you will see it has a number at the end. This is the number you must insert for this parameter below. It should be a number between 1 and 5000.
That is what the instructions say... No Popup appears in ANY Browser I own!
FSC830
Re: Install error
To be honest: then its a browser issue. Are you using a pop-up blocker?
In which part of Scotland are you located (guessing MM0 is your prefix, did not find the location on the fly
MM0ZIF
Re: Install error
got that one sussed now I have another load of issues, ISP is now dealing with them
