Block current
nitrx
Block current
Post by nitrx » Mon Sep 25, 2017 5:42 pm
Hi how do I disable UV in the block current conditions I've no solar nor uv sensor.
Thanks in advance (url http://apeldoornmeteo.nl )
Ron
Re: Block current
Post by Johnny » Mon Sep 25, 2017 5:58 pm
Hi Ron, if you don't have a solar sensor, go to the Administration section of your site, click on Main Setup and scroll about a quarter of the way down the page until you see Solar Sensor and change the setting to 'No'
Re: Block current
Post by Jachym » Mon Sep 25, 2017 6:05 pm
The reason you are seeing this is because whichever means of update you are using, is actually sending UV data (as 0, but it should not send anything, otherwise the template thinks you have this sensor).
Here is raw data sent to the API:
http://apeldoornmeteo.nl/meteotemplateLive.txt
You can see UV there
nitrx
Re: Block current
Post by nitrx » Mon Sep 25, 2017 6:07 pm
Johnny wrote: Mon Sep 25, 2017 5:58 pm Hi Ron, if you don't have a solar sensor, go to the Administration section of your site, click on Main Setup and scroll about a quarter of the way down the page until you see Solar Sensor and change the setting to 'No'
Thanks for thinking with me, it was alreay set to 'no' , I saved again but still uv shows up
Ron
nitrx
Re: Block current
Post by nitrx » Mon Sep 25, 2017 6:08 pm
Jachym wrote: Mon Sep 25, 2017 6:05 pm The reason you are seeing this is because whichever means of update you are using, is actually sending UV data (as 0, but it should not send anything, otherwise the template thinks you have this sensor).
Aha I now the problem I've a WH3080 so uvi data is sent, unfortunally the sensor is broken so no data comes in :roll:
well have to live with it , thanks anyway.
