I also moved my domain too, the server has php 8.2. Breckland Weather
I have multiple issues of which i have been trying for nearly 6 days now to sort out.
1, database is not updating
2, slow loading (in comparison, BW Leuven, BW PWS Dashboard and BW Saratoga)
3, items not working (steel gauges, the whole middle column)
I did hit it with
SET GLOBAL sql_mode=(SELECT REPLACE(@@sql_mode,'ONLY_FULL_GROUP_BY',''));I have also tried running the import script to backfill the days missing (jumping the gun, i know)
Test was spot on, no errors, ran the import and it says "Starting to parse data" and thats it,
Inspecting the page shows 60 of these errors...
importFile.php:1 Unchecked runtime.lastError: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was receivedI hope someone can shed some light on this, please.
Martin
