contact doesnt work
contact doesnt work
Post by meteoesine » Thu Jun 27, 2024 7:25 am
HI,
I noticed that the plugin no longer no longer sends emails for me, neither in PHP 8.3 nor in PHP 7.4. I tried reinstalling the plugin from the blog and changing my email but to no avail. Consequently, offline notification doesn't work either, although it doesn't display any anomalies (Everything OK :)
Have any of you encountered the same problem?
many thanks for any comments
Re: contact doesnt work
Post by meteoesine » Sat Oct 19, 2024 11:25 am
Hi there
I ask the question from the previous post again: am I the only one whose contact plugin no longer works?
have you tried to send yourself an email from the plugin? do you receive them?
tnx in advance for any comments
MeteoElMasnou
Software: Meteobridge + Weewx
Post by MeteoElMasnou » Mon Oct 21, 2024 6:42 am
meteoesine wrote: Sat Oct 19, 2024 11:25 am Hi there
Hi
The plugin CONTACT under php 7.4 works perfectly.
I just checked it.
Greetings
FSC830
Post by FSC830 » Sat Nov 02, 2024 7:00 am
Late reply... :?
Actually I can confirm that contact also runs with PHP 8.3.
But I noticed, that sending e-mails depends to the used e-mail program.
I am using ssmtp and needed to modify one line:
Original:
if(mail($to, "Webpage comment", $emailText, $headers)){
Modified:
if(mail($to, $subject, $emailText)){
This works perfectly in my test site.
At origin site I cant use the plugin because I cant install any mail program at host (missing permissions - it is a hosted web space).
Post by meteoesine » Sun Nov 03, 2024 6:16 am
thanks for reply
for my opinion the problem is not only a plugin problem but due to one of the recent structural changes of the template: I also noticed that it does not even send offline notifications anymore (it worked well some time ago)
tnx & regards
FSC830
Post by FSC830 » Sun Nov 03, 2024 7:49 am
Actually I never did use this at my live site, I just added the cron job to my test site and stopped updating.
A few minutes later offline notification dropped in.
Starting updating again the online mail receives within 1 minute.
So works as designed. :?:
Edit: can you send mails from hosts CLI?
Post by meteoesine » Sun Nov 03, 2024 6:57 pm
Hallo Frank
nothing to do, it's a problem of mine that I can't solve.
I can send and receive mails from my host's mail server but I can't start them from the template.
if I run the Test Email from the main setup it says: 'Test email has been sent. Close this tab and wait if it arrives' but nothing arrives...
mysterious mysteries
