Frustrated
spd2612
Software: Meteobridge Pro 2
Frustrated
Post by spd2612 » Sat Dec 20, 2025 8:03 pm
I originally started this with a WS2902a many years ago was dependable but not accurate Upgraded that to the WS5000 ,Rain and wind was alway's inaccurate but had a nice console
Ambient Weather had very poor support Out of frustration I went to Ecowitt with the Wittboy 2564 I have only had that about 7 months and Ecowitt support is not any better getting very high wind readings for hours and they are trying to say its debree but I have physicly checked it. my connection with meteotemplate is with the GW2000 AND THE ECOWITT plugin
so this time I am asking before I spend this kind of cash again
Looking at the wireless vantage pro 2 Pricey to start with
What do I have to have to get direct data upload from the Davis to Meteotemplate ?
Or any other reccomenditions I want to stay away from Fine Offset
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
cw3beck
Re: Frustrated
Post by cw3beck » Mon Dec 29, 2025 2:18 am
I've had the Davis Vantage Pro 2 since 2013 and have been very pleased with it. Have upgraded to the latest rain cone, installed the UV and solar energy hardware and upgraded to the daytime fan-aspirated and radiation shields along the way. Pull it down twice a year for a deep clean and has worked like a champ. I have been using Weather Display since 2010 and works well with Meteotemplate PHP code. I agree - it's not cheap but, for the price and accuracy, is the best for your money.
Re: Frustrated
Post by davidefa » Sat Jan 17, 2026 9:13 am
You can also try the davisWlLL plugin I wrote years ago.
Not sure if it is still up to date.
Last version should be the one attached
davisWLL_0.2.zip
(9.29 KiB) Downloaded 375 times
spd2612
Re: Frustrated
Post by spd2612 » Sat Jan 17, 2026 2:46 pm
David nice hering from you again I will look at the plugin
I do have the Davis ISS reporting thru the Meteobridge Pro 2 to Meteotemplate was not a cheap option but works well
I also have the wh57 which i am hoping is going to work have to wait on some lightning to see if it shows up in meteotemplate
I am using meteobridge http rather the using its built in meteotemplate plugin as i get faster updates that way
Davis Pro 2
Meteobridge Pro2
GW 2000
