Database Fields
wxthomson
Database Fields
Post by wxthomson » Thu Sep 28, 2017 12:15 am
Can someone tell me the field numbers for the meteotemplate csv database?
iatros
Re: Database Fields
Post by iatros » Thu Sep 28, 2017 6:09 am
Hello wxthomson
Fields are numbered by you:
log in as admin, then in Control Panel go to Database, Dataimport, txt/csv, Then you see a page like this one;
https://screenshots.firefox.com/LvfmKT7 ... dubler.com
You can set field numbers according to the columns of your csv import file, i.e.
Date/Time in one field: Field 0 (corresponding to column A in your csv)
Then e.g. Temp Field 1 (corr. to column B in your csv)
a.s.o
or
Date : Field 0
Time: Field 1
e.g. Temp: Field 2 a.s.o
HTH, Martin
Language Admin für Deutsch
Luc
Software: WeeWX
Re: Database Fields
Post by Luc » Thu Sep 28, 2017 12:42 pm
Hi wxthomson,
The explanation of Martin is true for a general csv file with meteotemplate data. The fields depends on the source which made the csv file.
When you are referring to the meteotemplate backup csv files, then the fields are as follows:
Column        DB field    Description
     0        DateTime    Date and Time
     1        T           Temperature
     2        Tmax        (max temp)
     3        Tmin        (min temp)
     4        H           Humidity
     5        D           (dewpoint)
     6        W           Wind speed
     7        G           Wind gust
     8        B           Wind Direction
     9        RR          Rain rate
    10        R           Cumulative daily precipitation
    11        P          Pressure
    12        S          Solar radiation
    13        A          (apparent temp)
See also my description how to import a Meteotemplate backup file in the Meteotemplate database.
How to import a backup of an alldata year file
http://meteotemplate.com/forum/viewtopi ... =183#p1101
Hope this helps
wxthomson
Re: Database Fields
Post by wxthomson » Thu Sep 28, 2017 5:27 pm
Thanks Luc
Just what i was looking for
