Hi.
Is it possible to remove the whole top bar upto the Home/admin bar. I dont want anything there at all at the top.
thanks
remove / customise top bar
- dmgould
Re: remove / customise top bar
If you mean the header -- You would have to change the code I believe. Alternately, you could turn off the title and subtitle and use a blank or solid colored custom image. I am trying to imagine a MT page without a title of some sort at the top.
make sure you do not delete the header, it does many other things apart from just showing the top banner. If you want to remove that, you need to hide it, not delete it.
To do this you would need to modify header.php to achieve this. This is a very unique wish so I dont think I will be implementing this in any future version for all.
