Steel Gauges appears completely empty
bribon
Post by bribon » Fri Oct 06, 2017 9:58 am
Hello from Spain. Since yesterday I have a problem. The Steel Series Gauges plugin appears completely empty ... I have tried to remove the plugin completely and reinstall it and it stays the same. When this happens, the block is also completely blank.
The link to the plugin is: http://astrometeopinedas.es/plugins/ste ... /index.php
(It also sometimes takes a long time to load the website but that's another issue ...)
Thank you!
Sin título.jpg (52.48 KiB) Viewed 4505 times
Re: Steel Gauges appears completely empty
Post by Jachym » Fri Oct 06, 2017 10:41 am
Several of the scripts (including jQuery) show Connection error, this is a server issue, it returns no data for these Javascript files, which however are fine on your server.
bribon
Post by bribon » Fri Oct 06, 2017 10:59 am
Thanks for your help. What can be the solution? Wait until my hosting fixes it or has nothing to do?
Post by Jachym » Fri Oct 06, 2017 11:51 am
probably, if there is a connection error, there is nothing I can do from my side, the scripts are ok
